DQMH Consortium Toolkits Feature Requests
ChrisFarmerWIS
Automate the Helper Loop Creation
Status: Released
Note that the implementation of this feature may be different from the one described in the feature request.
Credit goes to doyles for initially coming up with this idea.
Go here for previous discussions:
https://forums.ni.com/t5/Delacor-Toolkits-Discussions/Feature-request-Automate-the-Helper-Loop-creat...
My ideas for this are:
  1. Include a "checkbox" onto the Add New DQMH Module dialog panel that is labelled "Include a Helper Loop"
  2. If the user checks this checkbox, a helper loop is automatically added to the Main.vi
  3. The helper loop would not be a sub-VI, but simply a third loop on the main.vi block diagram.
  4. A Wake up Helper Loop request is automatically created and included in a Private Requests virtual folder
  5. Make the helper loop generic as per Sam's suggestion. My suggestion is to have three user events: 1) Timeout 2) <Stop Module> 3) <Wakeup Helper Loop>
  6. Label the additional "Register for Events" node something different from the other "Register for Events" node, ie. DQMH_REG_EVENTS_HELPER_LOOP (so that the Validate tool does not raise it as an issue)
  7. When generating a helper loop for new cloneable modules, ensure that in the "Wakeup Helper Loop" and "Stop Module" user events, that the Addressed to this Module.vi is used.
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
NI Silver Partner and Automated Production Test Specialty Premier Partner
https://wiredinsoftware.com.au
DQMH Trusted Advisor
1 Comment
Olivier-JOURDAN
Status changed to: Released
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
