DQMH Consortium Toolkits Feature Requests
ChrisFarmerWIS
Add a Validation test: Do all helper loops use DQMH Error Handler - Helper loop.vi
Status: Released
Available in DQMH 7.1
Please add a test to the Validate Module tool:
Find all while loops in the Main.vi of the specified module(s), and check if the DQMH Error Handler - Helper loop.vi is used to handle errors in each of the while loops, and flag it if not.  Ignore the default EHL and MHL in this check.
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
NI Silver Partner and Automated Production Test Specialty Premier Partner
https://wiredinsoftware.com.au
DQMH Trusted Advisor
4 Comments
Jens_S
I personally have quite a few HL that don't even have an error cluster cause there is nothing that could raise an error. If there is a simple way to disable this check I'm totally fine with it otherwise it would be rather inconvenient.
Darren
Proven Zealot
DQMH 6.1 and later includes the ability to right-click on validation failures and ignore them, as well as a button to manage all ignored failures for a module.
mbaudot
Status changed to: Development Started
Matthias Baudot | Software Architect | Founder & Owner at STUDIO BODs | DQMH® Consortium Board Member & Trusted Advisor
STUDIO BODs     LabVIEW Champion     Certified Professional Instructor     DQMH Trusted Advisor     DQMH Consortium Board Member     GCentral Sponsor
 Check out my LabVIEW presentations and videos!
Olivier-JOURDAN
Status changed to: Released
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
