05-24-2006 02:12 AM
05-24-2006 02:31 AM
Hi Moritz,
I did that, too - it was no problem.
Stefan
05-24-2006 02:39 AM
05-24-2006 02:45 AM
Matthias Alleweldt Project Engineer / Projektingenieur | Twigeater? |
05-24-2006 02:54 AM
Was denn jetzt?
Kein Problem? Doch evtl. ein Problem?
Ich möchte weiterhin die Programme/Skripte etc., die unter 9 laufen, benutzen (mit der 9er-Version). Können da Probleme auftreten, wenn ich 10 installiere, oder nicht?
05-24-2006 03:02 AM
Hi Moritz
In general there are no problems installing DIAdem 9.1 and 10 on the same computer. Do not install the two versions on the same folder.
Some parts of DIAdem register when you start DIAdem the first time. So I recomment that you should be login as administrator on your computer, when you switch between these programs. Even if you start both programs in parallel there are only very few interference between these two programs.
Winfried
05-24-2006 03:13 AM
