DIAdem
browseforfolder
I try to create a SUD-userdialog with a spezial button. This button
opens a new dialog, which should show all drives and subfolders on the
system.
I tried to use the VBS BrowseForFolder Method ("oFolder =
Shell.BrowseForFolder(Hwnd, sTitle, iOptions [, vRootFolder])").
It works great. But now I have to use an old operating system (Windows
NT 4.0 SP6.a, Iexplorer 6.0, shell32.dll version 4.0) and the method
doesnt work , because of the old shell32.dll. Is there any other
possibility to open a dialog to choose a folder?
thanks
Lutz
(5,198 Views)
Hi lutz,
There are two DIAdem commands that you can use to pop open a file/folder browsing dialog, both in VBScripts run from DIAdem as well as from SUDialogs, and they should both work on any Windows operating system:
FileNameGet() ..... opens a dialog to select a file
PathNameGet() ..... opens a dialog to select a folder
The DIAdem help describes each of these well, ask if you have further questions.
Brad Turpin
DIAdem Product Support Engineer
(5,198 Views)
thank you!
(5,197 Views)
even if this thread is rather old - a dummie question: I tried to use PathNameGet(), the dialog opens and everything, but from where do I get the selected path? I couldn'd find that in help. Is there a variable like FileDlgDir where the command stores this? The return value of PathNameGet() is only a dialog state.
Stefan
(4,975 Views)
Hello Stefan!
The variable is DlgOutputPath. It is documented in the 9.1 help.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,970 Views)
Thank you - I just looked into the 9.1 help and found it, too. In the Diadem 10 help, this information is missing Smiley Sad
Stefan
(4,969 Views)
Hi Stefan
in the next version of DIAdem you will find that information again in the help. It seems to be lost. Thanks for the feedback.
Winfried
(4,964 Views)
