DIAdem
Unwanted spaces in subscript text
My axis labels include unwanted spaces between characters when I use sub- and superscripts. For example, the text "Mean Longitudinal Acceleration to t^tn^n [m/s^h2^n]" is incorrectly spaced at the subscript n and superscript 2.
I've seen reference to this problem before but it seems it is still present (https://forums.ni.com/t5/DIAdem/Space-before-subscript-and-text-in-report-is-it-bug/m-p/3671419#M239...).
I'm using DIAdem 2021, so is this a bug that is still being carried forward version after version?
Simon.
(1,524 Views)
Hi Simon_Aldworth,
Thank you for this information. Yes, it seems that the more text there is before the formatting, the more spaces there are between the normal text and the formatted text.
One solution would be to split the text into two parts - one for the normal text and one for the formatted part.
I will inform R&D about this problem.
Greetings
Walter
(1,497 Views)
Thanks for your response Walter.
Unfortunately I can't easily use multiple parts for the text as they are axis labels. I would also need to use several parts as there is often more than one formatted character.
I look forward to a swift resolution to this rather aged problem.
Regards.
(1,488 Views)
