DIAdem
vector variable error in Diadem
When i try to run a new test with Diadem 9.0 version , I get this error message , but i don't know where to look for the vector variable in CustTLColVar column index.
Which file should i modify for this error or it is about vbs script modification?
(1,968 Views)
Hi ARBT2,
What I can see in the message box is that you are using a customer-created SUD " Vorbereitung" dialog that uses a " Kanaltab" control. There seems to be a variable "CustTLColVar" used with a wrong index parameter.
Greetings
Walter
(1,928 Views)
Hi Walter,
Thanks for you answer.
Problem is that i cannot find this CustTLColVAr variable to see what index parameter is wrong.
I opened a Dialog.cod file where I can find 'vorbereitung' and 'kanaltab' but no CustTLColVar.
(1,922 Views)
It seems that you work with very, very historical Scripts. You are talking about COD dialogs. More than 20 years ago we replaced COD dialogs with SUD dialogs. That is a long, long time. I know there was a dialog editor called “DlgEdit.exe”, but please excuse I am not familiar with this old technic.
Greetings
Walter
(1,912 Views)
