DIAdem
Trouble Calling Different Channels In a For Loop
I'm very new to DIAdem, but I haven't been able to find the answer I'm looking for. I wrote a little script to find the time difference between positions. I've named this TimeToValue.VBS. It gives me a message box with the time difference. I have the dim position changed to not be used in this script so that I can use it in the next script.
Option Explicit 'Forces the explicit declaration of all the variables in a script.
Dim RowA, RowB, RowC, RowD, TimeA, TimeB, TimeC, TimeD, ElapsedAB, ElapsedAC, ElapsedAD, A, B , C, D
Dim Position, TimeSpeed
'set Position = Data.Root.ChannelGroups(1).Channels("Run4NL")
set TimeSpeed = Data.Root.ChannelGroups(1).Channels("hz100&Time")
A = 0.025
B = 5
C = 15
D = 30
RowA = PNo(Position,A)
RowB = PNo(Position,B)
RowC = PNo(Position,C)
RowD = PNo(Position,D)
TimeA = TimeSpeed(RowA)
TimeB = TimeSpeed(RowB)
TimeC = TimeSpeed(RowC)
TimeD = TimeSpeed(RowD)
ElapsedAB = TimeB - TimeA
ElapsedAC = TimeC - TimeA
ElapsedAD = TimeD - TimeA
Call MsgBox("Time from "& A & "m to "& B & "m = " & ElapsedAB & "s" & vbNewLine & "Time from "& A & "m to "& C & "m = " & ElapsedAC & "s" & vbNewLine & "Time from "& A & "m to "& D & "m = " & ElapsedAD & "s")
Now I would like to call that same script in another one and loop through multiple runs. The channels are named "Run1RL", "Run2RL" etc.
Dim I, Position
For I = 1 To 3
Set Position = Data.Root.ChannelGroups(1).Channels("Run"& I &"RL")
Call ScriptInclude("TimeToValue")
Next
All I get from this one is the Run1RL and not any of the additional runs.
Additionally how do you output a list of values after I have defined the variables in the script. Currently I go through each one on its own and manually write them down from the message box. I remember outputting variables to a list in MATLAB, but it has been a couple years since I did that.
Tyler
(1,980 Views)
Accepted by TW_Test
Hey Tyler,
I recommend that you send the elapsed time results for each Run to a row in a set of ResultChannels in a new ResultGroup.  I've preserved the MsgBox output option for each row in case you still need it.  I also recommend that you use a simple Sub/Function declaration in the main VBScript.  You could have that Sub/Function in a different script file and ScriptInclude() it if you want, but for the purpose of this quick answer I left it all in one script.  I made up a fake data set to test the script with, and I'm including that as well-- just put the TDM/TDX files in the same folder as the VBScript file.
Brad Turpin
Principal Technical Support Engineer
NI
(1,936 Views)
Thanks Brad! That works exactly like I wanted it to and helped me figure out what to do with the data after I had a variable defined. This gives me some new vbs commands to look up too.
(1,925 Views)
