DIAdem
Steam Tables
Does anyone have Steam Tables (IAPWS-IF97) for Diadem? Or any kind of calculation model for steam/water properties?
Simple example: you have the pressure inside the vessel (as a channel) and want to know, which saturation temperature corresponds to it. The pressure channel exists, the temperature channel should be calculated.
We have an add-on for EXCEL, but I'd like to work direct in Diadem, without export/import of the data for every calculation.
(5,761 Views)
Hi Dia791,
I found a saturation table, which shows the saturation quantity over water (from -100 °C to 100 °C) and ice (from -100 °C to 0 °C)
Temperature in °CSaturation Quantity (water) in g/m³Saturation Quantity (ice) in g/m³
-100 4,5436 · 10^{-5} 1,7465 · 10^{-5}
-95 1,1432 · 10^{-4} 4,5752 · 10^{-5}
-90 2,7247 · 10^{-4} 1,1373 · 10^{-4}
-85 6,1778 · 10^{-4} 2,6939 · 10^{-4}
-80 1,3378 · 10^{-3} 6,1013 · 10^{-4}
-75 2,7765 · 10^{-3} 1,3260 · 10^{-3}
-70 5,5406 · 10^{-3} 2,7735 · 10^{-3}
-65 0,010661 0,005598
-60 0,019832 0,010930
-55 0,035750 0,020692
-50 0,062584 0,038056
-45 0,10661 0,068124
-40 0,17702 0,11890
-35 0,28700 0,20265
-30 0,45501 0,33776
-25 0,70640 0,55127
-20 1,0753 0,88211
-15 1,6068 1,3854
-10 2,3596 2,1380
-5 3,4086 3,2449
-4 3,6619 3,5205
-3 3,9316 3,8172
-2 4,2187 4,1363
-1 4,5239 4,4794
0 4,84843 4,84795
1 5,19317 -
2 5,55921 -
3 5,94766 -
4 6,35967 -
5 6,79642 -
6 7,25917 -
7 7,74919 -
8 8,26783 -
9 8,81648 -
10 9,39658 -
11 10,0096 -
12 10,6572 -
13 11,3408 -
14 12,0623 -
15 12,8232 -
16 13,6254 -
17 14,4707 -
18 15,3611 -
19 16,2984 -
20 17,2848 -
21 18,3224 -
22 19,4132 -
23 20,5596 -
24 21,7638 -
25 23,0283 -
26 24,3554 -
27 25,7477 -
28 27,2079 -
29 28,7385 -
30 30,3424 -
35 39,5623 -
40 51,0726 -
45 65,3114 -
50 82,7730 -
55 104,011 -
60 129,642 -
65 160,344 -
70 196,863 -
75 240,011 -
80 290,669 -
85 349,782 -
90 418,369 -
95 497,511 -
100 588,359 -
The general formula for calculating the saturation quantity [kg/m³] for water is:
(vapor pressure of water[Pa]) / (461,52[J/kg °C] * temperature[°C])
Formula for vapor pressure of water [hPa]:
6.112[hPa] * exp{ (17,62 * temperature[°C]) / (243,12[°C] + temperature[°C]) }
I hope this helps you implementing a function in DIAdem!
Matijas
(5,747 Views)
Hello Matijas,
thank you for support, but these are even the single values.
The formulas are helpful, they can solve at least a part of the problem.
(5,711 Views)
Accepted by topic author Dia791
Meanwhile the issue is cleared.
I could satisfy our IT people of necessity to work with new classes Smiley Happy
(5,683 Views)
