01-17-2013 10:42 AM
Does anyone have Steam Tables (IAPWS-IF97) for Diadem? Or any kind of calculation model for steam/water properties?
Simple example: you have the pressure inside the vessel (as a channel) and want to know, which saturation temperature corresponds to it. The pressure channel exists, the temperature channel should be calculated.
We have an add-on for EXCEL, but I'd like to work direct in Diadem, without export/import of the data for every calculation.
01-18-2013 08:10 AM
Hi Dia791,
I found a saturation table, which shows the saturation quantity over water (from -100 °C to 100 °C) and ice (from -100 °C to 0 °C)
Temperature in °C | Saturation Quantity (water) in g/m³ | Saturation Quantity (ice) in g/m³ |
-100 | 4,5436 · |
1,7465 · |
-95 | 1,1432 · |
4,5752 · |
-90 | 2,7247 · |
1,1373 · |
-85 | 6,1778 · |
2,6939 · |
-80 | 1,3378 · |
6,1013 · |
-75 | 2,7765 · |
1,3260 · |
-70 | 5,5406 · |
2,7735 · |
-65 | 0,010661 | 0,005598 |
-60 | 0,019832 | 0,010930 |
-55 | 0,035750 | 0,020692 |
-50 | 0,062584 | 0,038056 |
-45 | 0,10661 | 0,068124 |
-40 | 0,17702 | 0,11890 |
-35 | 0,28700 | 0,20265 |
-30 | 0,45501 | 0,33776 |
-25 | 0,70640 | 0,55127 |
-20 | 1,0753 | 0,88211 |
-15 | 1,6068 | 1,3854 |
-10 | 2,3596 | 2,1380 |
-5 | 3,4086 | 3,2449 |
-4 | 3,6619 | 3,5205 |
-3 | 3,9316 | 3,8172 |
-2 | 4,2187 | 4,1363 |
-1 | 4,5239 | 4,4794 |
0 | 4,84843 | 4,84795 |
1 | 5,19317 | - |
2 | 5,55921 | - |
3 | 5,94766 | - |
4 | 6,35967 | - |
5 | 6,79642 | - |
6 | 7,25917 | - |
7 | 7,74919 | - |
8 | 8,26783 | - |
9 | 8,81648 | - |
10 | 9,39658 | - |
11 | 10,0096 | - |
12 | 10,6572 | - |
13 | 11,3408 | - |
14 | 12,0623 | - |
15 | 12,8232 | - |
16 | 13,6254 | - |
17 | 14,4707 | - |
18 | 15,3611 | - |
19 | 16,2984 | - |
20 | 17,2848 | - |
21 | 18,3224 | - |
22 | 19,4132 | - |
23 | 20,5596 | - |
24 | 21,7638 | - |
25 | 23,0283 | - |
26 | 24,3554 | - |
27 | 25,7477 | - |
28 | 27,2079 | - |
29 | 28,7385 | - |
30 | 30,3424 | - |
35 | 39,5623 | - |
40 | 51,0726 | - |
45 | 65,3114 | - |
50 | 82,7730 | - |
55 | 104,011 | - |
60 | 129,642 | - |
65 | 160,344 | - |
70 | 196,863 | - |
75 | 240,011 | - |
80 | 290,669 | - |
85 | 349,782 | - |
90 | 418,369 | - |
95 | 497,511 | - |
100 | 588,359 | - |
The general formula for calculating the saturation quantity [kg/m³] for water is:
(vapor pressure of water[Pa]) / (461,52[J/kg °C] * temperature[°C])
Formula for vapor pressure of water [hPa]:
6.112[hPa] * exp{ (17,62 * temperature[°C]) / (243,12[°C] + temperature[°C]) }
I hope this helps you implementing a function in DIAdem!
Matijas
01-23-2013 03:05 AM
Hello Matijas,
thank you for support, but these are even the single values.
The formulas are helpful, they can solve at least a part of the problem.
01-28-2013 12:57 AM
Meanwhile the issue is cleared.
I could satisfy our IT people of necessity to work with new classes
