DIAdem
Reset clock to zero upon start save
I would like to reset my clock to zero upon commencement of the save of the measurement values., i.e. I need the first measured value to correspond to t=0s.   Is it possible to do this by connecting my start block to the reset input of the system clock? This brings up error messages.  Unfortunately the installation I am currently using does not allow me to carry out any measurements (simulated or otherwise).
Hel
(3,346 Views)
Hi Helend,
If you have a trigger which indicates when to create a new time channel starting with zero you can simply use the stop input of the save block. The parameters to set in the save block are:
Trigger: retrigger able
Data storage: With section creation -> Parameters: Use new channels for every measurement.
Attached you find a small example.
Greetings
Walter
(3,343 Views)
Thanks Rick,
I'm not sure how to apply this for my block diagram, which looks like the one attatched.  My system clock begins when I start the measurement but I want it to reset when the button "Startspeicher" is clicked.
Hope you can help,
Helen
(3,340 Views)
Hi Helend,
What do you think about the attacheched example?
Viele Grüße
Walter
(3,329 Views)
