Hi Colin,
Are you wanting to create a program using the DIAdem DAC Block Diagram
that saves particular data channels to a different file? Typically in
DIAdem the best way to do file manipulation and data storage once the
data is in place is through scripting, although admittedly I have
little experience with the DAC block diagram because it is not included
in the US version of DIAdem.
I think if this is related to the DIAdem DAC Block Diagram it would be
better answered by our German engineers here on the forums. If you just
want to save data from DIAdem programatically then you should be able
to use the DataFileSave function in the Script area of DIAdem to save
to a file.
Hope this helps - let me know if I've misundstood the question entirely.
Dan Weiland
	Dan Weiland
