DIAdem
Plotting data in diadem via LV
Is it possible to plot data in diadem by specifying the x and y axes values from LV at runtime? I am looking for a solution something like:
1. Load data into Diadem(give the command from LV).
2. Load layout into diadem(give the command from LV).
3. Specify the channels to be plotted from LV.
4. Plot data
5. Stop
Yash
(3,841 Views)
Accepted by Yashasvi
Hi Yash,
Please can you have a look at this piece of example code, I think it does what you have requested.
You will need to build up a customised array to insert the different channels. You will also need to know the name of your axis system in DIAdem, you can find this by hovering over the axis system in the report view of DIAdem and looking in the status bar at the bottom left of the application window.
JamesC
NIUK and Ireland
It only takes a second to rate an answer 🙂
(3,811 Views)
