DIAdem
png export fails with embedded txt object on tdr
I attempted to export the attached tdr as a png.
It fails with this error
1:08:07 PM Error:
Cannot open clipboard. (Error code 8:Not enough storage is available to process this command.
Using this call
CALL PicExport(REPORT_PATH,"PNG",true,768,593,"rgb 24",,"NoCompression") 'Exports the current sheet as WMF file
If you delete the text object it works fine.
jim
PS I had to laugh when it forbid me to attach the tdr directly.  Otmar get on the web team!
(4,293 Views)
Hello Jim,
I tried you layout on my PC (Windows XP SP3, 2 GB RAM, DIAdem 11.01) and could get a usable result. The output took a few seconds, but the result looks fine to me ...
Could you give me a few more pointers as to what your environment looks like?
I attached the output from my PC for your reference.
     Otmar
Otmar D. Foehner
(4,267 Views)
I basically  have the same setup running 11.0.0f3436
xp sp3
jim
(4,209 Views)
I opened the report layout you attached and made a new script with just the Call PicExport command you are using and ran it without error. In fact, my png file looked just like the one Otmar attached. I was using DIAdem 11.0.0f3436 and XP SP3.
(4,178 Views)
