 FIVES
			FIVES
			11-09-2017 05:12 AM
I have installed Diadem 2017 on my Professional computer this morning and after the end of the installation and the reboot of the computer, I got the error "Object required : 'navigator.display.currdataProvider'" appearing after the launch of Diadem.
I tried to reinstall but the same error appears.
Could someone help me to fix this ?
Thanks, regards
11-10-2017 02:23 AM
Hello FIVES,
It seems that during the installation process something was not correct registered. To solve this please try the following:
If this doesn't help try to repair DIAdem.
Greetings
Walter
11-10-2017 02:34 AM
Hi Walter,
Thanks for your reply.
I try the first option you gave me. Result is the following picture.
For the repairing of Diadem, I don't know where I can find the execute file. Could you tell me more about ?
11-10-2017 03:44 AM
Hi FIVES,
For the repairing option, you must open the OS area programs and features. There you find National Instruments Software. Double -click it, select the DIAdem version and Repair.
Greetings
Walter
11-10-2017 04:11 AM
Walter,
I've tried to repair Diadem, but as you'll find attached, I don't have any option for this. I can only remove the software.
Thanks for your help,
11-10-2017 07:24 AM
Hi FIVES,
It seems that you have installed one of the latest NI software products which provide a new kind of installer tool (Package Manager). In this case you have only the option to uninstall and install DIAdem again.
Greetings
Walter
 Alex_MKE
			Alex_MKE
			02-21-2018 02:13 PM
I am having the same issue plus additional issues with DataFinder in DIADem (attached) and have attempted to repair and reinstall both DIAdem and LabVIEW with no luck for solving this problem.
Has the previous user (FIVES) found a solution?
 Alex_MKE
			Alex_MKE
			02-21-2018 04:00 PM
SOLVED
According to previous reply, I found "uspSUsiMyDataFinderClient.uri" and running this file solved my problem.
Thanks!
