DIAdem
MAX,GfSNI-DAQ configuration problem?
What's the problem for this error(See attachment)?
How can I configure a simulated device in MAX?Is someting wrong with my configuration in MAX(See attachment)?
Message 1 of 11
(5,506 Views)
you are working with DAQmx. When you want to use it in DIAdem you have to create a Virtual Global Channel in MAX. This can be called from DIAdem, a DAQmx Task is in this case not working. This is for a simulated DAQmx Device and also for a real Device.
Hope this helps,
Rebecca Fox
Applications Engineer
Message 2 of 11
(5,455 Views)
I creat Global Virtual Channels(See attachment),still get the error,what's wrong with this?
Message 3 of 11
(5,439 Views)
When did you get this error? Which version of DIAdem are you using and which DAQmx?
Rebecca Fox
Message 4 of 11
(5,414 Views)
MAX: ver 4.0.0.3010
Diadem:9.10.2260
Message 5 of 11
(5,399 Views)
Sorry for late answering but I was ill.
In Diadem 9.1 it was necessary to choose the right driver. But this is only possible if you have installed an additional driver for DAQmx!
When you have installed it you can go into DAC module. There open the DAQ-Driver. In it you can chosse driver options and there you can change from Traditional DAQ to DAQmx.
Hope this helps,
Rebecca Fox
Message 6 of 11
(5,328 Views)
Thanks,it works.
But this dialog(see attachment)'s language becomes German, can it possible be English?
Message 7 of 11
(5,312 Views)
You´ve only written your MAX  verison, which DAQmx version are you using?
thanks,
Rebecca Fox
Message 8 of 11
(5,308 Views)
I don't where to find the information about the version,I just download this:
and use it.
Message 9 of 11
(5,302 Views)
Let´s start again. When you want to do DAQ with DIAdem 9.1 you need DAQmx and the additional DAQmx driver for DIAdem. The DAQmx version from your PC you can find in MAX under Software. There should be DAQmx, click on it and on the right sight you can see the version. Else, perhaps it´s easier to call NI. From which country are you?
Rebecca Fox
Message 10 of 11
(5,299 Views)
