DIAdem
Individually load all TDM files in folder
Here's what I'm looking to do.
1) Point DIAdem to a folder
2) Load first TDM
3) Perform Calculation
4) Save and close TDM
5) Load next TDM, and repeat for every TDM in the folder
I've come up with a script that I believe works, however it runs very slow. Is there anything I can do to speed it up?
Dim File, iCount, Directory
'-- Set Directory Path
Directory = "C:\_Processed Data"
'-- Load All TDM Files from Directory
File = DirListGet(Directory, "*.TDM", "filename", "FullFilenames")
For iCount = LBound(File) To UBound(File)
		Call DataFileLoad(File(iCount))
		'-- Calculations
		Call ChnIntegrate("[1]/Time","[1]/Pelvis RY","[1]/Pelvis Rotation RY","TrapezoidalRule",0,0,0)
		'-- Save and Clear
		Call DataFileSave(Directory&"\"&Data.Root.Name&".TDM","TDM")
		Call Data.Root.Clear()
	Next
(4,106 Views)
Accepted by TamerZero
Hi Tamer,
Your script looks OK to me.  If you want to know where your execution bottlenecks are, I suggest you turn on the Script Profiler in the SCRIPT panel and re-run your script.  It will give you a command-by-command breakdown of where your script is spending its time.
Brad Turpin
DIAdem Product Support Engineer
(4,066 Views)
Thanks Brad
(4,060 Views)
