DIAdem
Error when saving layout
Has this issue been resolved?  I am going nuts here trying to save a Report template and I keep getting the following type errors:
420  **** Error registered on 7/12/2005 at 5:19:15 PM [Message file:GLOBERR / Text area:1 / Text number:618]
     Error occured while loading REPORT object (see Logfile) of pict. descr. 2DObj3_Curve5!
421  **** Error registered on 7/12/2005 at 5:19:20 PM [Message file:GLOBERR / Text area:1 / Text number:618]
     Error occured while loading REPORT object (see Logfile) of pict. descr. 2DObj5_Curve6!
It appears that there is a 2DObj_Curve being created, which is no longer shown anywhere in the REPORTS, but is still associated with the REPORT file.  Is there a way to delete this un-released objects?  Is there a way to see all Objects, which are related to a REPORT?
Thanks.
Message 11 of 14
(1,222 Views)
Hi RichElswick,
As far as the behaviour is like Ingo described we fixed that for the next DIAdem revision.
Workaround: If you create a layout from scratch please, use the menu "File" -> "New" or the corresponding icon to delete the current layout. If you would like to delete a specific layout page use "Manage" of the tab context menu.
If your behaviour is different from this please describe the steps detailed. If I can reproduce the problem I will try to find a solution.
Greetings
Walter
Message 12 of 14
(1,215 Views)
Great, thanks and by next version, do you mean DIAdem 10?
When can we expect this to be out?
Message Edited by RichElswick on 07-14-2005 10:44 AM
Message 13 of 14
(1,211 Views)
Yes, that means DIAdem 10. The plan for shipping is December 2005 for SSP customers (Standard Service Program) and early in 2006 for customer without SSP.
Greetings
Walter
Message 14 of 14
(1,206 Views)
