DIAdem
Unknown Error
Hi everybody
                 Whenever i run a VBS file whose functionality is to plot some curves on the Graph Sheet , I get an error which says "Error occurred while loading Report object of pict. decr 2DYAxis2_1! " but I dont see any such error when I run the same file in some other machine. Im not able to find what that error is.
I would be glad if someone could figure out the cause of this error
I have attached the screenshot of that error along this posting.......
Regards
Andrew
(3,554 Views)
Hi Andrew,
I don't know what happens on this PC. Which DIAdem revision do you use (menu->help->about)? Please check whether you're using the latest DIAdem service pack. Does the McAffe virus rev. 8 scanner run on that PC?
Greetings
Walter
(3,553 Views)
hi Walter,
               My DIAdem version is 9.1. My Operating System is Windows 2000, and the machine where I checked it has got Windows XP.....
I dont have the latest service pack installed ..so could you provide me the link to download the latest service pack...
Regards
Philip
(3,546 Views)
Hi Philip,
no problem: www.ni.com/support/diasupp
DIAdem SP2 is a compleate installer and include a fix concerning the virus scanner problem. SP2b is a patch with small changes and requires SP2.
Greetings
Walter
(3,533 Views)
