DIAdem
DIAdem 2020 SP1: Error trying to create a new ANP file
I followed the steps at https://www.ni.com/documentation/en/systemlink/20.1/analysis/creating-analysis-automation-procedures/  -- when I click "OK" at Step 5, I get this error and the "Configure Analysis Automation Procedure" dialog disappears:
     Error in <TdmServerSuite_AnalysisServerConfig.SUC,AnalysisServerConfig> (Line: 611,Column: 5):
     SUD event context:
       btPacketNew_EventClick(...)
     Error in included script file <C:\PROGRAM FILES\NATIONAL INSTRUMENTS\DIADEM 2020\Resource\TdmServerSuite_AnalysisServerSimulation.VBC> (row/column) (813/5):
     SUD event context:
     Object required: 'oDlgASConf_M'
Any ideas what's causing this?
I've installed DIAdem 2020 SP1 on a few different PCs before and none of them had this error.
The error occurs on a machine with Windows Server 2012 R2, if that matters.
Certified LabVIEW Developer
(3,428 Views)
Accepted by topic author JKSH
Looks like an Control is not correctly registered.
Could you give us additional information.
Your System:
  • Windows Server 2012 R2
  • DIAdem 2020 Sp1
Is there additional NI software installed like:
  • Systemlink server
If yes which Version?
Do the other machines (the working ones) use different Windows versions?
If you open the "NI Package Manager manager" and call "Repair" on DIAdem.
Does the effect disappear? The Control should be registered again.
(3,374 Views)
Thanks, using "Repair" from NIPM fixed the issue.
Your System:
  • DIAdem 2020 Sp1
  • Systemlink server
The other (working) machines had various versions of Windows 7 -- 10, but none of them had Windows Server 2012 R2.
I can think of 1 other difference: All of the working machines installed DIAdem via NIPM's "Browse" functionality; the problematic machine installed DIAdem using an offline installer (ni-diadem-2020-en_20.1.0_offline.iso)
Here's the full list of NI software from nipkg.exe list-installed:
ni-activex-container	17.1.2.49152-0+f0
ni-apal-errors	19.0.0.49152-0+f0
ni-apxipm	19.0.0.49152-0+f0
ni-apxipm2	19.1.0.49152-0+f0
ni-assistant-framework	20.0.0.49152-0+f0
ni-assistant-framework-custom-ui-tool	20.0.0.49152-0+f0
ni-assistant-framework-labview-2017-support	20.0.0.49152-0+f0
ni-assistant-framework-labview-2017-x86-support	20.0.0.49152-0+f0
ni-assistant-framework-labview-2018-support	20.0.0.49152-0+f0
ni-assistant-framework-labview-2018-x86-support	20.0.0.49152-0+f0
ni-assistant-framework-labview-2019-support	20.0.0.49152-0+f0
ni-assistant-framework-labview-2019-x86-support	20.0.0.49152-0+f0
ni-assistant-framework-labview-2020-support	20.0.0.49152-0+f0
ni-assistant-framework-labview-2020-x86-support	20.0.0.49152-0+f0
ni-assistant-framework-ui-assemblies	20.0.0.49152-0+f0
ni-assistant-framework-x86	20.0.0.49152-0+f0
ni-auth	20.0.0.49152-0+f0
ni-cabled-pcie	20.0.0.49152-0+f0
ni-ceip	4.1.1.49152-0+f0
ni-ceip-x86	4.1.0.49152-0+f0
ni-certificates	2.0.3.49152-0+f0
ni-compactrio	20.0.0.49152-0+f0
ni-compactrio-max-support	20.0.0.49152-0+f0
ni-compactrio-runtime	20.0.0.49152-0+f0
ni-controllerdriver	20.0.0.49152-0+f0
ni-corba-namingservice	20.1.0.49152-0+f0
ni-curl	20.0.0.49152-0+f0
ni-cvi-analysis	19.0.0.49152-0+f0
ni-cvi-codegen	19.0.0.49152-0+f0
ni-cvi-tdms	19.0.0.49152-0+f0
ni-daqmx	20.0.0.49152-0+f0
ni-daqmx-config-support-core	20.0.0.49152-0+f0
ni-daqmx-devmon-support	19.0.0.49152-0+f0
ni-daqmx-labview-shared-docs	20.0.0.49152-0+f0
ni-daqmx-runtime-core	20.0.0.49152-0+f0
ni-datafinder-client-api	20.1.0.49155-0+f3
ni-datafinder-desktop-dc-eng	20.1.0.49155-0+f3
ni-datafinder-desktop-quit-dc	20.1.0.49155-0+f3
ni-dataplugins-aop5	19.5.0.7555-0+f2
ni-dataplugins-aop6	19.0.0.7435-0+f1
ni-dataplugins-audio	19.0.0.7438-0+f1
ni-dataplugins-python-host	20.1.0.49153-0+f1
ni-deployment-framework-x86	20.0.0.49152-0+f0
ni-device-monitor	20.0.0.49152-0+f0
ni-diadem-2020-core-en	20.1.0.49152-0+f0
ni-diadem-2020-dac-en	20.1.0.49152-0+f0
ni-diadem-2020-en	20.1.0.49152-0+f0
ni-diadem-2020-examples-en	20.1.0.49152-0+f0
ni-diadem-2020-license	20.0.0.49152-0+f0
ni-diadem-data-model	20.1.0.49152-0+f0
ni-diadem-worker	20.0.0.49152-0+f0
ni-dim	20.0.0.49152-0+f0
ni-ede	19.0.0.49153-0+f1
ni-erlang	22.2.0.49152-0+f0
ni-error-reporting-interface	20.0.0.49152-0+f0
ni-error-report-x86	20.0.0.49152-0+f0
ni-euladepot	20.0.0.49152-0+f0
ni-fpga-errorcodes	20.0.0.49152-0+f0
ni-fpga-errorcodes-x86	20.0.0.49152-0+f0
ni-help-assistant	2.2.0.49152-0+f0
ni-iotrace	20.0.0.49152-0+f0
ni-labview-2018-realtime-nbfifo-x86	18.0.1.49152-0+f0
ni-labview-2018-runtime-engine-resource	18.6.0.49152-0+f0
ni-labview-2018-runtime-engine-x86	18.6.5.49152-0+f0
ni-labview-2019-realtime-nbfifo-x86	19.0.0.49152-0+f0
ni-labview-2019-runtime-engine-resource	19.1.0.49152-0+f0
ni-labview-2019-runtime-engine-x86	19.1.2.49153-0+f1
ni-labview-2020-realtime-nbfifo-x86	20.0.0.49152-0+f0
ni-labview-2020-runtime-engine-resource	20.0.0.49153-0+f1
ni-labview-2020-runtime-engine-x86	20.0.1.49153-0+f1
ni-labview-broker	6.8.3.49152-0+f0
ni-labview-c-interface	1.0.4.49152-0+f0
ni-labview-system-state-publisher	20.0.0.49152-0+f0
ni-launcher	20.0.0.49152-0+f0
ni-license-manager	4.7.0.49152-0+f0
ni-linux-rt-pxi-base-image-20.0.0-realtime-bin	20.0.0.49152-0+f0
ni-linux-rt-pxi-base-image-20.1.0-realtime-bin	20.1.0.49152-0+f0
ni-linux-rt-pxi-system-image-20.0.0-realtime-bin	20.0.0.49152-0+f0
ni-linux-rt-pxi-system-image-20.1.0-realtime-bin	20.1.0.49152-0+f0
ni-linux-rt-system-image-20.0.0	20.0.0.49152-0+f0
ni-linux-rt-system-image-20.1.0	20.1.0.49152-0+f0
ni-logos	20.0.0.49152-0+f0
ni-logos-xt	20.0.0.49152-0+f0
ni-lv-web-server-labview-2018-runtime-engine-x86-support	18.0.1.49152-0+f0
ni-lv-web-server-labview-2019-runtime-engine-x86-support	19.0.0.49152-0+f0
ni-lv-web-server-labview-2020-runtime-engine-x86-support	20.0.0.49152-0+f0
ni-max	20.0.0.49152-0+f0
ni-max-remote-provider	20.0.0.49152-0+f0
ni-max-rempxi-provider	19.0.0.49152-0+f0
ni-max-software-provider	19.0.0.49152-0+f0
ni-mdbg	20.0.0.49154-0+f2
ni-mdfsupport	20.0.0.49152-0+f0
ni-mdnsresponder	19.0.0.49152-0+f0
ni-metasuite	19.0.0.49156-0+f4
ni-metauninstaller	20.0.0.49152-0+f0
ni-mkl-2017	17.0.1.49152-0+f0
ni-mkl-2018	18.0.1.49152-0+f0
ni-mkl-2020	20.0.0.49152-0+f0
ni-mru	20.0.0.49152-0+f0
ni-msdotnet4x	4.6.3.49152-0+f0
ni-msiproperties	20.0.0.49152-0+f0
ni-mssilverlight	5.1.9.49152-0+f0
ni-mstudio-cw3dgraph	8.7.5.49152-0+f0
ni-msvcrt-2008	9.1.1.49152-0+f0
ni-msvcrt-2012	11.1.1.49152-0+f0
ni-msvcrt-2015	14.1.5.49152-0+f0
ni-mxdf	20.0.0.49153-0+f1
ni-mximanager	20.0.0.49152-0+f0
ni-mxlc	20.0.0.49152-0+f0
ni-mxlc-core	20.0.0.49152-0+f0
ni-mxs	20.0.0.49152-0+f0
ni-networkdiscoverysvc	20.0.0.49152-0+f0
ni-opcenum	5.6.3.49152-0+f0
ni-opc-support	20.0.0.49152-0+f0
ni-opkg-feed-20.0.0-realtime-bin	20.0.0.49152-0+f0
ni-orb	20.0.0.49153-0+f1
ni-p2p	20.0.0.49152-0+f0
ni-package-manager	20.5.0.49152-0+f0
ni-package-manager-deployment-support	20.5.0.49152-0+f0
ni-package-manager-released-feed	20.6.0.49316-0+f164
ni-package-manager-upgrader	20.6.0.49316-0+f164
ni-pal	20.0.0.49152-0+f0
ni-pal-errors	19.5.0.49152-0+f0
ni-pcibrd	20.0.0.49152-0+f0
ni-pie	20.0.0.49152-0+f0
ni-portable-configuration	19.5.0.49152-0+f0
ni-ptpsysapi-runtime	20.0.0.49152-0+f0
ni-pxiplatformframework	20.0.0.49152-0+f0
ni-pxiplatformframework-errors	19.5.0.49152-0+f0
ni-pxiplatformservices-expert	20.0.0.49152-0+f0
ni-pxiplatformservices-provider	20.0.0.49152-0+f0
ni-pxiplatformservices-runtime	20.0.0.49152-0+f0
ni-pxiplatformsoftware-errors	19.0.0.49152-0+f0
ni-python-interface	20.0.0.49154-0+f2
ni-qpxi	20.0.0.49152-0+f0
ni-rabbitmq	3.8.2.49152-0+f0
ni-realtime-error-dialog	19.0.0.49152-0+f0
ni-registration-wizard	1.0.8.49152-0+f0
ni-remote-configuration	20.0.0.49152-0+f0
ni-resetniconfig	19.0.0.49152-0+f0
ni-rio-fpga-driver	20.0.0.49152-0+f0
ni-rio-fpga-ids	20.0.0.49153-0+f1
ni-rio-max-support	20.0.0.49152-0+f0
ni-rio-mite	19.0.0.49152-0+f0
ni-roco	20.0.0.49152-0+f0
ni-roco-errors	20.0.0.49152-0+f0
ni-rpc	19.0.0.49152-0+f0
ni-rpc-19.0.0-realtime-bin	19.0.0.49152-0+f0
ni-rtsi-core	20.0.0.49152-0+f0
ni-rtsi-pal	20.0.0.49152-0+f0
ni-rtsi-ui	19.1.0.49152-0+f0
ni-securityupdate-kb67l8lcqw-killbits	2.1.0.49152-0+f0
ni-serial	20.0.0.49152-0+f0
ni-serial-config	20.0.0.49152-0+f0
ni-serial-runtime	20.0.0.49152-0+f0
ni-skyline-alarminstance-service	20.1.0.49152-0+f0
ni-skyline-alarminstance-webservice	20.1.0.49152-0+f0
ni-skyline-api-webservice	20.1.0.49152-0+f0
ni-skyline-connectors-common	20.1.0.49152-0+f0
ni-skyline-core-services	20.1.0.49152-0+f0
ni-skyline-dashboardbuilder-webui	20.1.0.49152-0+f0
ni-skyline-dashboardui	20.1.0.49160-0+f8
ni-skyline-data-consoles-common	20.1.0.49152-0+f0
ni-skyline-dataplugins-service	20.1.0.49152-0+f0
ni-skyline-dataplugins-webservice	20.1.0.49153-0+f1
ni-skyline-file-service	20.1.0.49152-0+f0
ni-skyline-file-webservice	20.1.0.49152-0+f0
ni-skyline-file-webui	20.1.0.49152-0+f0
ni-skyline-jupyterhub-service	20.1.0.49152-0+f0
ni-skyline-license-webservice	20.1.0.49152-0+f0
ni-skyline-message-client	20.0.0.49152-0+f0
ni-skyline-message-client-x86	20.5.0.49152-0+f0
ni-skyline-message-service	20.1.0.49152-0+f0
ni-skyline-nodejs	20.1.0.49152-0+f0
ni-skyline-notification-service	20.1.0.49152-0+f0
ni-skyline-notification-webservice	20.1.0.49152-0+f0
ni-skyline-rabbitmq-support	20.1.0.49152-0+f0
ni-skyline-redis-support	20.1.0.49152-0+f0
ni-skyline-repo-service	20.1.0.49152-0+f0
ni-skyline-repo-webservice	20.1.0.49152-0+f0
ni-skyline-repo-webui	20.1.0.49152-0+f0
ni-skyline-security-webui	20.1.0.49152-0+f0
ni-skyline-service-manager	20.1.0.49152-0+f0
ni-skyline-serviceregistry	20.1.0.49152-0+f0
ni-skyline-smtp-service	20.1.0.49152-0+f0
ni-skyline-system-health-monitoring-rules	20.1.0.49152-0+f0
ni-skyline-systemsstate-service	20.1.0.49152-0+f0
ni-skyline-tag-client-x86	20.5.0.49152-0+f0
ni-skyline-tag-historian-service	20.1.0.49152-0+f0
ni-skyline-tag-historian-webservice	20.1.0.49152-0+f0
ni-skyline-tagruleengine-service	20.1.0.49152-0+f0
ni-skyline-tagruleengine-webservice	20.1.0.49152-0+f0
ni-skyline-tag-service	20.1.0.49152-0+f0
ni-skyline-tag-webservice	20.1.0.49152-0+f0
ni-skyline-tag-webui	20.1.0.49152-0+f0
ni-skyline-tdmreader-service	20.1.0.49152-0+f0
ni-skyline-tdmreader-webservice	20.1.0.49152-0+f0
ni-skyline-tracelog-webservice	20.1.0.49152-0+f0
ni-skyline-user-service	20.1.0.49152-0+f0
ni-skyline-wif-webservice	20.1.0.49152-0+f0
ni-skyline-wif-webui	20.1.0.49152-0+f0
ni-slcp	4.1.1.49152-0+f0
ni-slcp-x86	4.1.0.49152-0+f0
ni-sqlsrv2012-nativeclient	19.6.0.49152-0+f0
ni-ssl-labview-2018-runtime-engine-x86-support	18.0.1.49152-0+f0
ni-ssl-labview-2019-runtime-engine-x86-support	19.0.0.49152-0+f0
ni-ssl-labview-2020-runtime-engine-x86-support	20.0.0.49152-0+f0
ni-ssl-support	20.0.0.49152-0+f0
ni-svcloc	20.0.0.49152-0+f0
ni-sync	20.0.0.49152-0+f0
ni-sync-api-support	20.0.0.49152-0+f0
ni-sync-atomic-api	20.0.0.49152-0+f0
ni-syncdomain-service	20.0.0.49152-0+f0
ni-sync-iotrace-support	20.0.0.49152-0+f0
ni-sync-wrapper	20.0.0.49152-0+f0
ni-sysapi	20.0.0.49152-0+f0
ni-sysapi-webservice	20.0.0.49152-0+f0
ni-sysapi-wif	20.0.0.49152-0+f0
ni-syscfg-dotnet-runtime	20.0.0.49152-0+f0
ni-syscfg-runtime	20.0.0.49152-0+f0
ni-sysmgmt-common	20.1.0.49152-0+f0
ni-sysmgmt-discovery-service	20.1.0.49152-0+f0
ni-sysmgmt-license	20.1.0.49152-0+f0
ni-sysmgmt-salt-master-support	20.1.0.49152-0+f0
ni-sysmgmt-service	20.1.0.49152-0+f0
ni-sysmgmt-webservice	20.1.0.49152-0+f0
ni-sysmgmt-webui	20.1.1.49153-0+f1
ni-system-configuration	20.0.0.49152-0+f0
ni-systemlink-alarm-notification-webui	20.1.0.49152-0+f0
ni-systemlink-client-2020.1-realtime-shared	20.1.0.49153-0+f1
ni-systemlink-client-2020-realtime-shared	20.0.0.49152-0+f0
ni-systemlink-cloud-connector-service	20.1.0.49152-0+f0
ni-systemlink-cloud-connector-webservice	20.1.0.49152-0+f0
ni-systemlink-cloud-connector-webui	20.1.0.49152-0+f0
ni-systemlink-dataplugins-webui	20.1.0.49153-0+f1
ni-systemlink-document-manager-service	20.1.0.49152-0+f0
ni-systemlink-document-manager-webui	20.1.0.49153-0+f1
ni-systemlink-jupyterhub-module	20.1.0.49153-0+f1
ni-systemlink-nosqldatabase-4.2	20.1.0.49152-0+f0
ni-systemlink-notebook-execution-service	20.1.3.49152-0+f0
ni-systemlink-python-3.7	20.1.2.49152-0+f0
ni-systemlink-python-3.7-jupyterhub	20.1.2.49152-0+f0
ni-systemlink-python-3.7-systemlink-sdk	20.1.2.49152-0+f0
ni-systemlink-server	20.1.0.49154-0+f2
ni-systemlink-server-common	20.1.0.49152-0+f0
ni-systemlink-server-license	20.1.0.49152-0+f0
ni-systemlink-software-config-module	20.1.1.49152-0+f0
ni-systemlink-tdm-analysis	20.1.0.49154-0+f2
ni-systemlink-tdm-datafinder	20.1.0.49154-0+f2
ni-systemlink-tdm-data-preparation	20.1.0.49154-0+f2
ni-systemlink-user-data-service	20.1.0.49152-0+f0
ni-systemlink-webui-branding	20.1.0.49152-0+f0
ni-systemlogging-utils	20.0.0.49152-0+f0
ni-system-webserver	20.0.0.49152-0+f0
ni-system-webserver-appserver	20.0.0.49152-0+f0
ni-system-webserver-base	20.0.0.49152-0+f0
ni-targetdiscoverywizard	20.0.0.49152-0+f0
ni-tdm-excel-addin	19.0.0.49152-0+f0
ni-tdms	19.0.0.49152-0+f0
ni-tdmserver	20.1.0.49154-0+f2
ni-tdmserver-2020r2-client	20.1.0.49152-0+f0
ni-tdmserver-database	20.1.0.49152-0+f0
ni-tdmserver-datafinder-shared	20.1.0.49154-0+f2
ni-tdmserver-demodata	20.1.0.49152-0+f0
ni-tdmserver-infrastructure	20.1.0.49153-0+f1
ni-tdmserver-nodecore	20.1.0.49154-0+f2
ni-tdmserver-webui	20.1.0.49154-0+f2
ni-tdmserver-webuiframework	20.1.0.49152-0+f0
ni-traceengine	20.0.0.49152-0+f0
ni-update-service	19.0.0.49152-0+f0
ni-usblan	19.0.0.49153-0+f1
ni-usblandevice-systemapi	18.5.0.49154-0+f2
ni-usbvcp	6.7.6.49152-0+f0
ni-usi-core	20.1.0.49155-0+f3
ni-variable-engine	20.0.0.49152-0+f0
ni-visa	20.0.0.49152-0+f0
ni-visa-configuration	20.0.0.49152-0+f0
ni-visa-documentation	20.0.0.49152-0+f0
ni-visa-errors	20.0.0.49152-0+f0
ni-visa-headers	20.0.0.49152-0+f0
ni-visa-interactive-control	20.0.0.49152-0+f0
ni-visa-passport-enet	20.0.0.49152-0+f0
ni-visa-passport-enet-serial	20.0.0.49152-0+f0
ni-visa-passport-gpib	20.0.0.49152-0+f0
ni-visa-passport-pxi	20.0.0.49152-0+f0
ni-visa-passport-remote	20.0.0.49152-0+f0
ni-visa-passport-serial	20.0.0.49152-0+f0
ni-visa-passport-tulip	20.0.0.49152-0+f0
ni-visa-passport-usb	20.0.0.49152-0+f0
ni-visa-runtime	20.0.0.49152-0+f0
ni-visa-shared-components	5.12.0.49152-0+f0
ni-visa-sysapi	20.0.0.49152-0+f0
ni-webserver	20.1.0.49152-0+f0
ni-webserver-webservices	20.1.0.49152-0+f0
ni-webserver-webservices-amqp	20.1.0.49152-0+f0
ni-wif	20.0.0.49152-0+f0
ni-wifcoredeps	20.0.0.49152-0+f0
ni-wsrepl	20.0.0.49152-0+f0
ni-xerces-delay-load	2.7.10.49152-0+f0
ni-xlator	19.5.0.49152-0+f0
ni-xnet	20.0.0.49152-0+f0
ni-xnet-core	20.0.0.49152-0+f0
ni-xnet-runtime	20.0.0.49152-0+f0
ni-xnet-utilities	20.0.0.49152-0+f0
system-windows-x64	20.5.0.49152-0+f0
(3,348 Views)
