DIAdem
DIADEM MAP VIEW
I try to use the "Map View" and I get stuck when I realized my registration data in the cache.
My computer work and nothing is recorded, I have the information at the bottom left that appears: please wait, the map data is saved to the hidden Being ... "
Of empty folders create this but nothing is recorded in the inside.
THANKS FOR YOUR HELP,
Vincent POTTIER
Essais Véhicules, valves et Systèmes / Vehicles,valves and systems Test
POCLAIN HYDRAULICS
BP 106 - 60411 Verberie Cedex - FRANCE
Message 1 of 19
(8,256 Views)
Did you try it without "registration data in the cache"?
Simyfren
Message 2 of 19
(8,209 Views)
Thank you for you help,
I tested without "registration data in a cache",here does not work, the map is displayed but the gps  coordinates do not correspond to the map display, i dont no why?
Popote
Message 3 of 19
(8,198 Views)
Try to check: Show track, then press OK and then Play (Ctrl+F5).
Simyfren
Message 4 of 19
(8,195 Views)
Show track, then press OK and then Play (Ctrl+F5).:
here does not work either nothing moves!Robot Sad
Message 5 of 19
(8,191 Views)
And do you see the track?
I had also problems with moving, and the problem was the correct format of time channel.
Simyfren
Message 6 of 19
(8,189 Views)
You can see my format of time channel (seconds), with view when i play the curves.DIAdem - [VIEW   EXAMPLE.TDV]1.png
Message 7 of 19
(8,185 Views)
The map does not match my test area (Germany while my tests are France)
Message 8 of 19
(8,185 Views)
And If you try manually "move to France" and try to find your GPS position, do you see your track?
Simyfren
Message 9 of 19
(8,180 Views)
I realized one more chance, that you don't have a correct GPS data format.
Simyfren
Message 10 of 19
(8,176 Views)
