11-27-2007 11:40 AM
11-27-2007 03:30 PM
Hello AlexP1!
A script is the right thing for you and not to difficult. Try the 'Teach in' mode in the SCRIPT device. Once started you can proceed as normal with your calculations. All steps will be recorded and you can edit the result as you like.
Matthias
| Matthias Alleweldt Project Engineer / Projektingenieur | Twigeater? |
11-28-2007 09:08 AM
Hi Alex,
By "Teach-In", Twigeater means the VBScript Recorder, which you can turn on in the SCRIPT panel, and I heartily endorse this suggestion. What you will get when you do this is a series of commands like the following:
DIAdem 10.2 or later
Call ChnCalculate("Ch(""Channel 1 Eng"") = 34.093*Ch(""Channel 1"")-169.46")
Call ChnCalculate("Ch(""Channel 2 Eng"") = 32.093*Ch(""Channel 2"")-160.46")
DIAdem 10.1 or earlier
Call FormulaCalc("Ch('Channel 1 Eng') := 34.093*Ch('Channel 1')-169.46")
Call FormulaCalc("Ch('Channel 2 Eng') := 32.093*Ch('Channel 2')-160.46")
Note that the "FormulaCalc" commmands will work in DIAdem 10.2 and later as well, and for large channels these will actually run faster than the "ChnCalculate" commands. The advantage of the "ChnCalculate" commands is that they can contain all VBScript functions and operate on string channels, neither of which the "FormulaCalc" commands can do.
Brad Turpin
DIAdem Product Support Engineer
11-29-2007 08:44 AM
