DIAdem
Command for closing groups in the data portal
can I use a command in a script to close all groups in the data portal (same like Pressing "/" on the num pad).
Gabriel
(4,600 Views)
Accepted by topic author fischerg
Hello Gabriel,
you can use
Portal.Structure.Collapse(Data.Root)
DIAdem supports the API's PORTAL and DATA since version 11.
Greetings
Walter
(4,599 Views)
I put the code
    Call ChnRenumber()
in a script and stored it in a file (script.vbs).
Then I assigned the script to one of the script-buttons (to use with shift an F1-F12).
If I press Shift+F12 (my assigned Shortcut), I realize that the script is executed, but nothing happens in the Dataportal. I press the correspondent button it works?
Why??
Gabriel
(4,554 Views)
Hello Gabriel,
You are right. That seems to be a wrong behavior. But here is a work-around:
Pause 0.01
Greetings
Walter
(4,552 Views)
Hello Walter,
Thanks, it works.
(4,549 Views)
