04-05-2012 05:18 AM
does anyone know if it is possible to create a "Ueberrollungsklassierung" with DIAdem? To do so, I always have to use another programm before going on with DIAdem.
Thanks in advance,
Joe
04-05-2012 03:45 PM
Hello Joe,
I have done some research on "Überrollungsklassierung" and found different descriptions of what this can or should be online.
Could you provide some more detailed insight into what this functions is supposed to do, maybe a reference to a specific algorithm or paper discussion the method.
Otmar
04-10-2012 12:59 AM
Hello Otmar,
thank you for your answer.
The function I am looking for is supposed to show in a 2D graph, how many kilometers (rounds óf the wheel) a car drove at a specific torque. The inputs are rpm of the Cardan shaft and the torque working on the Cardan shaft. I also know the gear ratio of the transfer-case and the dimensions of the wheel.
Joe
