DIAdem
ACCESS VIOLATION error in Report
I am getting an access violation when trying to save a report.  The report only has two worksheets.  ONe is a table of contents and one of them is a template for plotting data.
Error while executing "PicSaveAs(FileDlgName)" command
Error Type: ACCESS VIOLATION
Error Address: 89FFEE10
Module Name: DIAdem.exe
I am using Diadem 2011.
Basically, I am trying to create a template file to make plots with.  I have a script that copies my template plot, plots the next channel, and repeats for all channels in the data portal.  The script works fine, and I got it to run once.  HOwever, I wanted to make a change, and something happened to my original template file.  So I open my report with 100 pages, delete all pages (and by the way WHY CAN I NOT DELETE MORE THAN ONE PAGE AT ONCE?  this is very annoying that i have to do this one at a time (and confirm every time) either by manage or delete options) except one, and I try to save this as my template plot and I get this error...tried several times...Any ideas?
jason
(4,705 Views)
Hello Jason,
would you be so kind to post the report (tdr file) making the trouble?
Greetings
Andreas
(4,695 Views)
Hello Jason,
a workaround for you could be to open two instances of DIAdem. Open your report in DIAdem one.
Open first page and select "Edit->Select All" and "Edit->Copy" go to your second DIAdem and open Report with an empty report. Select "Edit->Paste" and your template is restored.
Greetings
Andres
P.S.: Please post your report anyway if possible to help us to find the issue.
(4,693 Views)
Regarding your question " Why can I not delete more than one page at a time?":
If you right-click on a page tab and then select "manage" you get a list of all your pages. You can select several pages at once using "shift". Then you can click the delete button in the upper right corner of the list.
Let me know if this doesn't work for you
Andreas
(4,683 Views)
Thanks AndreasH_Ha!  We have been communicating on the ideas page.
(4,681 Views)
