DASYLab
substr & strfmt
Hey
I have a text string of 24 digits (too long for a variable). I want to convert the first 3 digits to a variable.
I know I should use substr and strfmt commands, but how do I implement them in Dasylab?
Benny
Denmark
Message 1 of 9
(11,819 Views)
Which version DASYLab do you have?
How do you get the string? via RS232?
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
Message 2 of 9
(11,814 Views)
Hey
I using both Ver 8 and 9.  I am rebuilding our oldest test machine (ver 8 ).
The input er by barcode reader. Input from keyboard by Action -> Enter String.
Benny
Message 3 of 9
(11,812 Views)
I just realized that I didn't install DASYLab in this lapto but, unless somebody can answer this today, I will try this weekend.  I am not atthe office today.
In any case, in Ver 9, you can perform many string manipulation action in the string variable section.
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Message 4 of 9
(11,810 Views)
Accepted by topic author Højvælde
This should be the same in V8 and V9.
Set up an extended Expression in a global variable
The formula is
strval(substr ( ${STR_1}, 1,3 ) )
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 5 of 9
(11,808 Views)
Hey
Yes it is solved.
Benny
Message 6 of 9
(11,803 Views)
I use the Expression in the variable property setting. The formular is:  strval (substr (${STR_1} ,3 , 4) )
It works well in my simulation program. But when I write this small program with my main program, it shows some error. The screenshot ist linked to this subject. Al the setting are same. I am so confused. Can somebody help me?? I  will very appreciate that.
Thank you very much!!
Message 7 of 9
(6,880 Views)
I do not get this message when I set up as you have done.
What does the current value of the string look like?
Also, what version of DASYLab are you using?
Message 8 of 9
(6,875 Views)
Hi CJ,
I  want to use Dasylab to collect some data from a device through a RS232 module.
There are 2 types of Intput Signal. One is started with "A" and the other one is started with "B". And I have already set these two Signals into String 1 and 2. (use fomular "A" a $1 \r) Now I want to seperate these String into different variables. An example is showed below.
string1: 861200  into Variable1: 86  Variable2: 1200
Version of DASYLab is 2016 Basic
Message 9 of 9
(6,871 Views)
