 Simon-lee
			Simon-lee
			08-29-2016 04:12 AM
I looking to add a warning to the operator when sensor calibration is overdue or/and the number of days left until that date.
Therefore, I’m looking to compare the current date with a pre-defined date and flag a warning when that date is in the past or the period in days until that date.
I have used this functionally with the NI-DAQmx driver but to use my current hardware I will need to manage this function within the worksheet.
Has anyone any suggestions on how to approach this problem,
Thanks in advance
DASYLab V13 full (v16 on preorder)
Windows 7 SP1
Delphin expert key L 200
		08-30-2016
		05:09 AM
 - last edited on
		02-05-2024
		10:18 AM
 by
		 migration-bot
			migration-bot
Dear Simon-Lee,
Thank you for your question, as DASYLab is still natively supported by Measurement Computing, I would recommend contacting them for the best support.
08-31-2016 06:18 AM
Thanks for the suggestion I have fired off the question to MCC, I will leave this thread open for a short while so I can add their solution. 🙂
09-25-2016 04:08 AM
The great guys at Measurement Systems Ltd (https://www.measurementsystems.co.uk the UK distributer of DASYLab) have got Back to me. The solution involves a script module but I don’t feel entitled to post it here because it isn’t my work. I sure if you pop over to MSI they will be more than happy to help.
09-26-2016 08:37 AM
I'm really glad that the Script helped. The Script module in DASYLab Full and Pro gives you an added level of customization for tasks like this, where DASYLab doesn't have a specific feature.
I've got a bunch of example scripts at kb.mccdaq.com and am more than happy to provide a sample script for this or other tasks.
