DAQExpress
Simulating noise and writing it: too many channels error
I am using the simulate noise express VI and running it to a DAQ assistant that has one channel and is writing data. When I input the white noise signal, it says I am inputting 10 channels where my task only has one channel. I have no idea how to fix this as it does not seem like the white noise has 10 channels, I have even checked by signal splitting and checking outputs of each on charts.
Thank you in advance
(737 Views)
Accepted by Merkimer
Start with attaching your VI.
(Since you talk about VIs, this looks like a LabVIEW question and I am not sure why you are posting in daqexpress forum)
(722 Views)
Hi Altenbach,
My mistake I thought this was the forum to talk about issues with express VIs specifically, but I realize this is wrong. But I have since figured it out! It was just a down sampling issue, but thank you for your time nonetheless!
(713 Views)
