annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
PCI 6601 Counter/Timer problem - Can the board do the job ?
Hi there! My name is Michael from Politehnica University of Bucharest Romania and we are interested in PCI-6601 Counter/Timer board.We want to develop an application with the following option :
-simultaneous reading of 2 counters of the board (count edges) on which the pulses are ariving with 300 Khz frequency AND generating of a 20Khz PWM signal using another counter of the board (continuous pulse train generation)
I know that the PCI-6601 has 1 DMA channel and 3 IRQ's channels.
My question to you is : Can the PCI-6601 acomplish the mission (the simultaneous reading of the 2 counters and generating of a PWM signal using another counter) when the counters are using ONLY interrupts ?
We are using a P
II 400 Mhz with 64 Mb Ram.
I'm waiting for your answers as soon as possible.
Michael.
0 Compliments
Message 1 sur 3
3 740 Visites
Greetings Michael,
You are correct in that the PCI-6601 only has one DMA channel; however, the DMA channel is only used during buffered operations. If you plan on using the Count Edges (NI-TIO).vi example (twice, since you have 2 counters to read from) and using the Generate Pulse Train (NI-TIO).vi example for the continuous pulse train generation, you should not have any issues with the DMA channel. Now, if you try to start 2 copies of the Count Buffered Edges (NI-TIO).vi example you will receive an error stating you do not have an available DMA channel to complete the operation. The key word in the last example is *buffered*. In this case you have 2 options, use the PCI-6602 which has 3 DMA channels or use interrupts for some of your transfers.
Th
e biggest downfall to interrupts is the speed at which you can complete your operations. Please refer to the Data Sheet and Specifications for the PCI-6601. This can be found on our website at http://www.ni.com or via the link below.
PCI-6601
http://sine.ni.com/apps/we/nioc.vp?cid=3589〈=US
On the last page of this Data Sheet you will see that for continuous operations using interrupts you are limited to a rate of 10kS/s.
Justin Britten
Applications Engineer
0 Compliments
Message 2 sur 3
3 740 Visites
Hi Justin!
Thank you for your answer,i must ask you some more questions about this :
1.In the vi examples from the NI-TIO library (Count Edges (NI-TIO).vi and Generate Pulse Train (NI-TIO).vi)it isn't specified explicit how the counting or the PWM generation it is performed through DMA's or IRQ's.I know if i want to perform the operation through IRQ's i must explicit specify that using "Set DAQ Device Information".But if i don't specify that, which is the case here in your vi examples how the operations (the counting and the PWM generation) are performed ?
Can you give me a vi example in where the counting/generation of the PWM it's performed explicit (using Set DAQ Device Information) through IRQ's ?
2. In a control loop there is a limitatio
n speaking in terms of time regarding the signal acquisition time, the processing time , and the generation of the output signal time ? What i mean is if i have a control loop at 10 ms for example, using of the interrupts for 3 counters (i use 2 incremental encoders and i control a DC Motor with PWM signal so i use another counter for PWM generation of the output signal) will be enough to perform the control task ? How fast must i aquire the signals and generate the PWM signal to acomplish the control job ? Obviously all 3 operations : aquire,processing,generating the PWM signal should be performed in 10 ms.
Thank you very much for reading this and i'll be waiting for your answer as soon as possible.
Michael.
0 Compliments
Message 3 sur 3
3 740 Visites
