Hi Justin!
Thank you for your answer,i must ask you some more questions about this :
1.In the vi examples from the NI-TIO library (Count Edges (NI-TIO).vi and Generate Pulse Train (NI-TIO).vi)it isn't specified explicit how the counting or the PWM generation it is performed through DMA's or IRQ's.I know if i want to perform the operation through IRQ's i must explicit specify that using "Set DAQ Device Information".But if i don't specify that, which is the case here in your vi examples how the operations (the counting and the PWM generation) are performed ?
Can you give me a vi example in where the  counting/generation of the PWM it's performed explicit (using Set DAQ Device Information) through IRQ's ?
2. In a control loop there is a limitatio
n speaking in terms of time regarding the signal acquisition time, the processing time , and the generation of the output signal time ? What i mean is if i have a control loop at 10 ms for example, using of the interrupts for 3 counters (i use 2 incremental encoders and i control a DC Motor with PWM signal so i use another counter for PWM generation of the output signal) will be enough to perform the control task ? How fast must i aquire the signals and generate the PWM signal to acomplish the control job ? Obviously all 3 operations : aquire,processing,generating the PWM signal should be performed in 10 ms.
Thank you very much for reading this and i'll be waiting for your answer as soon as possible.
Michael.
