Counter/Timer
How can I use analog signal trigger my PXI-6115 counter to generate frequency pulse
I'm working on  a PXI-6115 DAQ card and want using analog signal to trigger it's counter generate frequency pulse. The user manual says the analog trigger is supported, but  I can't use a analog signal to trigger it start work, in the test I use counter 0 to generate pulse and use PFI 0 as analog trigger signal input port, can anyone tell me what the matter is? My test VI. & error message is showing in attachment .
Best regards
(6,210 Views)
Accepted by walletok
If you read the error you can see that digital triggers are the only available trigger when using Counter Output.
You can get around this by setting up a dummy Analog Input task that will fire an internal digital trigger when it sees the appropriate analog trigger.
See this thread for more details:
http://forums.ni.com/t5/LabVIEW/DAQmx-Start-Trigger-Analog-Edge-vi-Keeps-Returning-Error-200077/m-p/...
CTA, CLA, MTFBWY
(6,205 Views)
Hi, snowpunter
Thanks for your response.
AnologComparisonEvent is a evil event, Even if 6115 analoge channels without retrigger function, it can offer a internal trigger pulse  everytime  the analoge trigger signal fit pre-set trigger state. Now I use AnalogComparisonEvent as CO clock source and CO task is working properly .
(6,196 Views)
