06-18-2012 01:11 AM
I'm a little confused, because the ATM Machine example instructions seem to imply you're supposed to create the front panel from scratch. It also gave specifications on the Account.txt file.
However, some posts on this board have led me to believe that a GUI (and even data files) are provided for you ahead of time.
For people who have actually taken the exam: do I need to practice throwing the GUI together when I run through the practice exams, or should I be copying over the front panel from the solution?
Thanks.
06-18-2012 04:35 AM
In my opinion, you should be prepared to do everything. However, I agree that recent discussions have suggested the Front Panel is now given to you.
06-18-2012 06:55 AM
It seems like the FP is given to you (as yenknip said), I'll take the exam shortly I will let you know what they give to you.
The sample exams are old exams so they are not updated.
06-18-2012 09:29 AM
Additionally, if you are prepared to draw the FP and you find out you don't, then you've gained an extra 20-30 minutes
06-18-2012 09:32 AM
In your exam packet, a USB stick will be provided. The USB stick will have the following:
We are currently in the process of updating the sample exams to reflect this change. The updated samples will be available in the first week of July.
Zaki Chasmawala | Certification Development Group Manager | Training & Certification | National Instruments | certification@ni.com
06-18-2012 09:35 AM - edited 06-18-2012 09:38 AM
Zaki beat me to it. Long response deleted. 🙂
Mallori
11-21-2017 03:25 AM
As you said, "SubVIs" and "Controls" folder is available in "USB Template" folder.
Both the folders are empty, .ctl file is not available for Sprinkler and ATM example program.
http://www.ni.com/gate/gb/GB_EKITCLDEXMPRP/US.
Plz check the above link.
11-21-2017 08:31 AM
Hi ksathish,
This post is over 5 years old. Were you just making a comment on the CLD exam? If you have a question, it would be best to start a new thread to address it.
11-24-2017 01:18 AM
Ok..
@Gregory wrote:
Hi ksathish,
