BreakPoint
Why some people say Local Variables are bad...
@altenbach wrote:
Scary thing is that everything apparently worked before updating to 64bit windows .... These race conditions can lurk unseen.! 😞
Actually, the logic is there 4 or 5 ways to shut down the loops (That's what makes it so darned confusing)  but those loop timers just leave everything to chance on when data gets to em
"Should be" isn't "Is" -Jay
Message 351 of 396
(8,459 Views)
Yeah, I have a customer (used to be coworker) who just upgraded computers on an older test system.  I thought for sure the race conditions in the main VI was going to bite them hard.  Apparently they didn't upgrade enough.
Message 352 of 396
(8,456 Views)
After all that the problem moving from 32 bit to a 64 bit system was.....
Spoiler
he deployed an exe to the 64 bit target and thought FP Close would exit the application instance.Smiley Surprised
Message 353 of 396
(8,440 Views)
The start of an abuser, see here
Original code:  Oh Boy... I forgot about the snippet creator... should have used code grabber..
Same without Locals
Message 354 of 396
(8,418 Views)
What is even crazier is how he keeps track of the maximum value:
As I wrote here:
You seem to want to keep track of the maximum value. Also here you are making huge mistakes. First you append the value to the front of an array (which is much less efficient than adding to the end of an array). Then you keep the array in an uninitialized shift register, meaning that you retain old data between runs. Then you are growing the array forever, (or until you run out of memory). All you need to keep is a scalar value containing the current max!
Here's my a quick alternative that only needs to keep 8 bytes in memory, as opposed to searching for array max in an evergrowing array.
Message 355 of 396
(8,411 Views)
There is a new idea out to make local variables "good again", whatever that means.
See for yourself and either vote or abstain 😄
I will abstain. 😉
Message 356 of 396
(8,318 Views)
Why do we get all these horrible suggestions here?
"Wire as many local variables to all the case outputs to as yopu wish to see it blink as the code executes."
"Create local variable for all & inside loop make it true & outside make it false"
(If the guy would post his actual code, we could turn it into a state machine without any local variables in a few minutes....)
Message 357 of 396
(8,226 Views)
For some reason I see the guy that posted the Variables Idea having this expression when he was informed about the Declined Status:
http://cdn.memegenerator.net/instances/400x/32647588.jpg
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 358 of 396
(8,210 Views)
Local Horror!!
Discussed here
The locals span 3 screens down!  The code is incomprehensible..
Message 359 of 396
(8,118 Views)
Maybe he loves floating items? 🙂
<40 posts to go for 10k heroism!
How long will it take?
A day or 2?
Kind Regards,
Message 360 of 396
(8,108 Views)
