BreakPoint
Rube Goldberg Code
So we acquire dynamic data but ultimately are only interested in a single scalar. I pointed this out, so the OP "fixed" it as follows (seen here😞
Message 2231 of 2,571
(10,764 Views)
Here's a small section of non-scalable code (see the navigation windows for the full size, seen here)
... and yes, it can be simplified and made more scalable with code that would fit half of a postcard. (took me just a few minutes once I got to my desktop with a bigger screen).
Message 2232 of 2,571
(10,759 Views)
If someone sees the point of doing this, please explain me...
False case is empty; Sending false in the subvi just send an empty path to a file.
Message 2233 of 2,571
(10,728 Views)
Certainly a bit convoluted, but we don't really have enough information to judge because you left out what the subVI does if it receives a TRUE. I don't even know what "sending a path to a file" really means.
The true case executes whenever the control changes and that's a valid scenario. So far we don't even know the mechanical action. 😉
Message 2234 of 2,571
(10,724 Views)
The Feedback Node and the Not Equal are detecting if the value changed.  Seems valid to me.  I would need to know a lot more on what the rest of the code is doing before making any comments about the empty path to a file.
GCentral
Message 2235 of 2,571
(10,721 Views)
Yep fair enough, sorry.
The mechanical action is Switch when Released, and a false action sends an empty string to a shared variable that is read and  "somewhere else" in the code.
The compilation of Monday+tiredness+this code is just making me grumpy ^^
Have to admit, I'm kinda off-topic here sorry.
Message 2236 of 2,571
(10,726 Views)
At least it's neat...
Bill
CLD
(Mid-Level minion.)
Message 2237 of 2,571
(10,681 Views)
Meaningless array operations (seen here)
Message 2238 of 2,571
(10,509 Views)
To show progress using a variable length (max=9) row of LED apparently needs two case structures, 81 visible properties, 72 local variables, and 9 separate LEDs and terminals. Herding cats!
(Seen here)
All we really need is one array of LEDs, one property node, and a little bit of code. Right?
Message 2239 of 2,571
(10,366 Views)
For your patient, an array seems spot on!
There are situations where an array (or cluster) isn't possible.
On plant P&IDs the controls and indicators can be scattered all around. As we can't have clusters with controls and indicators, a cluster of controls will block the cluster of indicators.
I'd do this, and all handling of controls and indicators, by reference and label. It's not ideal though.
I also tend to get customers that not only want to have Boolean values, but also want my code to enable\disable them. That also rules out arrays.
Message 2240 of 2,571
(10,334 Views)
