 Neos
			Neos
			10-19-2013 04:38 AM
http://forums.ni.com/t5/LabVIEW/How-to-sort-an-array-in-Even-and-odd-parts/td-p/2595717
Says - there are thousands of ways to do it.
           He did it rubes way
using locals is not crime - yeah i have heard it
10-23-2013 04:03 PM - edited 10-23-2013 04:03 PM
Well, at least if fits comfortably on a 640x480 screen. (and that's all we had back in the days!) 😄
 KoenR94
			KoenR94
			12-10-2013 08:52 AM
Found this rube goldberg topic.
Most of you may have seen this gem.
It can be found here
12-10-2013 10:55 AM
Curiously, the discussion is titled "how to increase the memory of VI".
While most people try to reduce the memory footprint of a VI, this example seems to already do exactly the opposite, i.e. what he wants. 😄 So where is the problem?
 jcarmody
			jcarmody
			12-10-2013 11:54 AM
01-24-2014 10:25 AM - edited 01-24-2014 10:27 AM
interesting way to change the filename part of a long path (seen here).
(There is a path-to-string implied as first operation)
One better way (NeilR):
 crossrulz
			crossrulz
			01-30-2014 10:45 AM - edited 01-30-2014 10:45 AM
Found here:http://forums.ni.com/t5/LabVIEW/Moving-live-data-from-inside-for-loop/m-p/2721769#U2721769
Build an array from 1 item and index it out. We've seen that a million times. What caught my funny bone is the fact that they are using a Quotient & Remainder to divide the FOR loop iteration count by 1 and taking the remainder. So much work just to put a value in a chart.
01-30-2014 10:55 AM
crossrulz wrote: So much work just to put a value in a chart.
It is probably the classic:
"Hey I don't know LabVIEW but after trying random things seen elsewhere, this works, so I won't touch it and possible mess it up again" 😄
02-22-2014 12:39 PM - edited 02-23-2014 10:57 PM
Adding a few sine waves apparently needs code the height of the empire state building (seen here).
Here's the navigation window (the white area is a typical screen size!)
02-22-2014 01:08 PM - edited 02-22-2014 01:09 PM
Two Index arrays, two subtractions, two squaring, addition, square root, etc. to get a distance between two point in 2D. (seen here).
Complex math IS simpler! 😄
