BreakPoint
Rube Goldberg Code
http://forums.ni.com/t5/LabVIEW/How-to-sort-an-array-in-Even-and-odd-parts/td-p/2595717
Says - there are thousands of ways to do it.
           He did it rubes waySmiley Wink
using locals is not crime -  yeah i have heard it
Message 1391 of 2,641
(12,056 Views)
Well, at least if fits comfortably on a 640x480 screen. (and that's all we had back in the days!) 😄
(seen here)
Message 1392 of 2,641
(11,968 Views)
Found this rube goldberg topic.
Most of you may have seen this gem.
It can be found here
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
Message 1393 of 2,641
(11,775 Views)
Curiously, the discussion is titled "how to increase the memory of VI".
While most people try to reduce the memory footprint of a VI, this example seems to already do exactly the opposite, i.e. what he wants. 😄 So where is the problem?
Message 1394 of 2,641
(11,742 Views)
It looks like it was generated with scripting by placing & wiring random nodes, although the Run arrow isn't broken.  It makes want to write a LabVIEW fractal generator...
Jim
Message 1395 of 2,641
(11,718 Views)
interesting way to change the filename part of a long path (seen here).
(There is a path-to-string implied as first operation)
One better way (NeilR):
Message 1396 of 2,641
(11,487 Views)
Found here:http://forums.ni.com/t5/LabVIEW/Moving-live-data-from-inside-for-loop/m-p/2721769#U2721769
Build an array from 1 item and index it out.  We've seen that a million times.  What caught my funny bone is the fact that they are using a Quotient & Remainder to divide the FOR loop iteration count by 1 and taking the remainder.  So much work just to put a value in a chart.
Message 1397 of 2,641
(11,367 Views)
crossrulz wrote: So much work just to put a value in a chart.
It is probably the classic:
"Hey I don't know LabVIEW but after trying random things seen elsewhere, this works, so I won't touch it and possible mess it up again" 😄
Message 1398 of 2,641
(11,354 Views)
Adding a few sine waves apparently needs code the height of the empire state building (seen here).
Here's the navigation window (the white area is a typical screen size!)
Message 1399 of 2,641
(11,211 Views)
Two Index arrays, two subtractions, two squaring, addition, square root, etc. to get a distance between two point in 2D. (seen here).
Complex math IS simpler! 😄
Message 1400 of 2,641
(11,205 Views)
