BreakPoint
Rube Goldberg Code
@altenbach wrote:
Edit: Yes, I was right. Just checked my LabVIEW 4.0 installation and it does not have the insert/delete function in the array palette.
Any idea when these functions were introduced?
- Partha ( CLD until Oct 2027 🙂 )
Message 1591 of 2,635
(13,270 Views)
@crossrulz wrote:
Don't look so surprised.  He also has a copy of LabVIEW 3.
 Haha, ofcourse he does. I should have seen that coming. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 1592 of 2,635
(13,243 Views)
/Y
No, that's only a demo (See here. Fully functional in windows XP mode, but cannot save anything).
OTOH, LabVIEW 4.0 is still installed on the same computer where I learned LabVIEW (Windows 95, Pentium 1). PC is running 24/7 (for almost 20 years!) controlling an instrument via an ISA card AT-MIO-16E-1.
I wish I remember. Maybe 6.0? (I think that was the first beta I participated). 😄 All upgrade notes are available somewhere, so it would be a matter of looking through them to see what's mentioned about array functions. (Use google to search for specific upgrade notes, the NI search is useless for this :()
(I remember that I did not really like some of the unwired behavior, because it was not in line with the typical definitions (e.g. typically an unwired index means element 0, but for "delete from array", it means the last element of the array. This is of course useful but also somewhat confusing.))
Message 1593 of 2,635
(13,205 Views)
My copy came with the upgrade suite.  Have not played with it enough to try anything.  But the lack of the autotool is really annoying.
Message 1594 of 2,635
(13,201 Views)
Yes, my memory was correct. These functions got introduced in LabVIEW 6i.
Looking at the LabVIEW 6i upgrade notes, we find the following statement.
Array Function Enhancements
"LabVIEW includes three new functions for manipulating arrays — the Replace Array Subset, Insert Into Array, and Delete From Array functions, available in the Functions»Arrays palette ..."
Message 1595 of 2,635
(13,182 Views)
Thank God! I started my career with 6i ! 🙂 Can't imagine life without those 3 array muskateers.
Message 1596 of 2,635
(13,156 Views)
We haven't seen that kind of useless boolean gymnastics in a while. but look at the code posted here.
Here are a few parts in no particular oder. 😄
Lete's look at the middle and bottom case:
  1. If the boolean is true, we go to the true case
  2. in the true case we compare it with TRUE, just to be sure
  3. If it is really true, we abort the VI, so why does it even matter what we wire to the stop condition?
  4. If the boolean is false, we go to the FALSE case.
  5. In the FALSE case, we compare it to FALSE, just to be sure
  6. Since the comparison is guaranteed to returne TRUE, we need to invert in order to not to stop the loop
We would get exactly the same functionality by wiring the control directy to the stop condition (and potentially branch the wire to the abort primitive, but that sounds a bit clumsy ;)) No case structure or boolean gymnastics needed. 😮
Message 1597 of 2,635
(12,974 Views)
(seen here)
How would you change a scalar to an array with one element?
Well, "built array" resized to one input would come to mind.....
......but wouldn't it be so much better to use a "ptbypt data queue" configured for a queue size of one element?
Well, yes, at least if we are getting paid by the size and complexity of the code! 😄
Message 1598 of 2,635
(12,867 Views)
@altenbach wrote:
"ptbypt data queue"
I didn't even know that node existed.
Message 1599 of 2,635
(12,837 Views)
@Hornless.Rhino wrote:
@altenbach wrote:
"ptbypt data queue"
Just to give it some credibility.  My hideous self embarassment yesterday was due to the use of that node.  (As an nZ-Transform)  Delay / dT = n samples in the queue
Dont leave dT = 0 you don't have enough memory, trust me ok?
"Should be" isn't "Is" -Jay
Message 1600 of 2,635
(12,750 Views)
