BreakPoint
Rube Goldberg Code
Hmm,
For some reason the word "chosen" made me think about the following:
chosen
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 1181 of 2,641
(12,708 Views)
complicated.pngThe event is Subtract background: Value change.
I didn't realise at first that this was the same as:
Message 1182 of 2,641
(12,591 Views)
Not really RG code. I usually leave controls unconnected and use the outputs from the event structure.
PaulG.
Retired
Message 1183 of 2,641
(12,560 Views)
Not really RG code either, but I am always amazed what passes as "solution" these days. 😄
(This is almost like in politics 🐵
(seen here)
Message 1184 of 2,641
(12,509 Views)
(seen here)
Where is that Me Too button when it could be useful Smiley LOL
"Should be" isn't "Is" -Jay
Message 1185 of 2,641
(12,501 Views)
Splitting an integer representing seconds into hours, minutes, and seconds can be done in many ways, some are easier than others (seen here😞
Same thing (would work equally well with DBL):
To be fair, P@Anand probably had a ready-made VI that provided also days, etc.
That reminds me of a joke about a mathematician making cheese...
On the first occasion he pours the milk in the pot, lights the fire, puts pot over fire, stirs, etc.
On the second occasion the fire is already lit and the milk is in the pot (I guess the cleaning lady was helping out). The mathematician extinguishes the fire, pours the milk back in the bottle and cleans the pot. Thus he has reduced it to a problem that her knows how to solve from experience. 😄
Message 1186 of 2,641
(12,377 Views)
I can't tell you how many times I have done this exact same code.  Then I started making a reuse library.  Except I didn't flip my minutes and hours...:smileytongue:
EDIT:  Just noticed you corrected yourself between postings.  Oops.
Message 1187 of 2,641
(12,364 Views)
Achieving perfection is an iterative procedure with no real enpoint... 😄
Message 1188 of 2,641
(12,345 Views)
At least I'm to the point where I admit when I screw up...
Message 1189 of 2,641
(12,339 Views)
Some are even easier.   😄
Note: the timestamp to time record can actually take a dbl but the number to timestamp function is just soooooo pretty
Message 1190 of 2,641
(12,337 Views)
