BreakPoint
Rube Goldberg Code
My turn at creating a RG code...
That's what happens when you try to do something quickly..
original code:
improved:
Yes... yes, I am aware of the coersion dots...  😛
Message 1141 of 2,641
(13,721 Views)
Well, it could be simplified further - you're taking the 1D array of RGB values and then turning it into 3 2D arrays of RGB values and then making that into a 3D array.
So you could move the build array to be after the decimate and then do the reshape in a loop.
Or you could use the picture VI which converts a flattened pixmap to a 2D U32 array and then use split number on that array to extract the RGB arrays.
___________________
Try to take over the world!
Message 1142 of 2,641
(13,695 Views)
Some code can only be described as tapeworms: ugly, unwanted, and hard to get rid of.
(Seen here)
Message 1143 of 2,641
(13,607 Views)
Generating a regularly patterned 3D array, then slicing out one of the planes in a given orientation may need a multiscreen sized diagram, case structures with the same property node on all cases, shift registers, empty arrays, intermediary array of 1, 2, 3 dimensions, stacked loops, etc.
(note that the above picture is scaled to 50% of the actual size!).
Or it could all be done with some simple postcard sized code. 😄
(seen here)
(more details)
Message 1144 of 2,641
(13,404 Views)
      I think. when I code some times,no need to purposefully make it as a Rube Goldberg Code,it will naturally turn to a Rube Goldberg CodeSmiley WinkAnyway I think Rube Goldberg Code will disappears gradually as experience build up...
Thanks as kudos only:)
Message 1145 of 2,641
(13,370 Views)
Either that or you just find more and more nitty-gritty things to optimise.
Message 1146 of 2,641
(13,331 Views)
Same thing
LabVIEW 2012
Message 1147 of 2,641
(13,269 Views)
Same can be easily represented as:
Message 1148 of 2,641
(13,190 Views)
In the above code just take few number of bytes and reversing it inside an array.
Message 1149 of 2,641
(13,189 Views)
In the above RGC,If the array size is getting bigger and bigger then definitely the first one will become a Rube Goldberg one.Smiley Very Happy
Message 1150 of 2,641
(13,181 Views)
