在 08-18-2008 11:05 AM
IT seems dynamic event registration fails if the respective front panel is not open. Since a corresponding error is generated, this might be an expected limitations.
Still, I cannot find this documented anywhere, so at a minimum it is a documentation bug.
This limitation should be removed if possible or at least be documented in the help for "Register For Events".
See this discussion for an example and more details.
The Get Panel Image method does not include the background image:
http://forums.lavag.org/Front-Panel-Capture-Problem-t11727.html
在 08-23-2008 07:44 PM
在 08-29-2008 11:23 AM
This is either a bug or a feature change.
LabVIEW 8.6 improperly handles Shift+Right Click
shift-right-click on a FP object:
Entering a free text label on tab control causes label to be entered about 45 pixels higher than cursor position in LV8.6
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=352449#M352449
