BreakPoint
Monthly Bugs, October 2008
This is the continuation of the September 2008 bug thread.
The rules are as always:
  1. Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  2. One post/bug!
  3. One bug/post!
  4. No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message Edited by Support on 10-01-2008 10:37 AM
Message 1 of 32
(12,730 Views)
Altenbach:
I think you skipped a millenia 🙂
-AK2DM
Message 2 of 32
(12,707 Views)
Ouch! I have Laura correct it. 🙂
Message 3 of 32
(12,702 Views)
Setting a VI to "locked(no password)" does not "stick". (LabVIEW 8.6 only)
Next time the VI is opened, it is no longer locked.
See: http://forums.ni.com/ni/board/message?board.id=170&thread.id=359029&jump=true
Message 4 of 32
(12,679 Views)
The new version of the DB toolkit no longer handles closed recordset references in the Fetch Recordset Data VI:
http://forums.ni.com/ni/board/message?board.id=170&thread.id=359049
___________________
Try to take over the world!
Message 5 of 32
(12,647 Views)
LabVIEW 8.6 runs out of memory for trivial code that runs fine in earlier versions:
http://forums.ni.com/ni/board/message?board.id=170&message.id=359886&jump=true
Message 6 of 32
(12,590 Views)
Bug with animate windows when minimizing and maximizing
http://forums.ni.com/ni/board/message?board.id=170&thread.id=360297
Message 7 of 32
(12,529 Views)
Potential bug when using EXTended precision with an Intensity Graph in LabVIEW 8.5.
Unconfirmed... but have a look at this thread:  http://forums.ni.com/ni/board/message?board.id=170&thread.id=360616
R
Message 8 of 32
(12,499 Views)
LabVIEW incorrectly reuses a buffer when using a shift register and reading from a cluster element and writing to it:
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=362124#M362124
___________________
Message 9 of 32
(12,385 Views)
http://forums.ni.com/ni/board/message?board.id=170&message.id=362315
Bug where a saved back VI from 8.6 to 8.5.1 is not recognised in VBAI as valid VI. A native 8.5.1 VI is.
André (CLA, CLED)
Message 10 of 32
(12,337 Views)
