BreakPoint
Monthly Bugs (November 2005)
This is the continuation of the October 2005 monthly bug thread..
Rules:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
  • Ed Dickens - Certified LabVIEW Architect
    Lockheed Martin Space
    Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
    Message 1 of 10
    (8,697 Views)
    Quote from Altenbach from last months bug listing.
    "With LabVIEW 8.0 coming out, this could be a very interesting month!"
    So here's the first one.
    http://forums.ni.com/ni/board/message?board.id=170&message.id=149725
    Seems to be a problem with the Request Deallocation function
    Ed
    Message 2 of 10
    (8,679 Views)
    Read about the broken "X-controls" in this thread.
    http://forums.ni.com/ni/board/message?board.id=170&message.id=150920&jump=true
    Ben
    Message 3 of 10
    (8,629 Views)
    plotting data in timezone with loose fit enabled goes wrong
    when plotting data from a 10 second data fetch and plotting with loose fit enabled.
    I get an x-axis of 1 hour and 10 seconds. (local time Greenwich -1)
    If I change the timezone to Greenwich the loose fit works Ok
    This did work correctly in 7.1
    greetings from the Netherlands
    Message 4 of 10
    (8,596 Views)
    This post points to a flaw in the code for the "switch until released" mechanical action of booleans:
    http://forums.ni.com/ni/board/message?board.id=170&message.id=152108#M152108
    It seems if the switch is set to false via a local variable while it is still pressed, the later button release will trigger another false-true transition. (The button release seems to trigger an inversion of the current state instead of forcing an off).
    Message 5 of 10
    (8,558 Views)
    File permission bug in "Open Create Replace WDT Array Dlog File.vi" under LV 8.0
    http://forums.ni.com/ni/board/message?board.id=170&message.id=151455
    A work around exists, but that does not change the fact that the
    Deny Access.vi is not working as expected.
    Message Edited by jasonhill on 11-18-2005 09:50 AM
    Message 6 of 10
    (8,504 Views)
    Annotation re-draw needs a little more work, see here.
    http://forums.ni.com/ni/board/message?board.id=170&message.id=153618
    to see artifact of the old annotations not being erased properly before being re-drawn.
    Other than that I really like the new annotation feature!
    Ben
    Message 8 of 10
    (8,427 Views)
    Message 9 of 10
    (8,394 Views)
    This thread is now closed.
    Let's continue in the December Bug Collection ! 😄
    Message 10 of 10
    (8,316 Views)
