BreakPoint
Monthly Bugs (July 2006)
This is the continuation of the June 2006 monthly bug thread.
Rules:
  1. Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  2. One post/bug!
  3. One bug/post!
  4. No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 13
(10,266 Views)
chillycharlie ... r u still maintaining a buglist excel sheet? ... I thought it was great but I haven't seen an update since about may ...
Greycat
PS - altenbach ... I was unsure as to who closed/opened these threads or if it was open to the community .... but now I know ... thanks 😉
Message 2 of 13
(10,267 Views)
Greycat
Stop being so shy ! ;):D
The buglist is opened to anyone willing to help. Add your own discoveries and publish it again. You will even get some more stars.
PDA bug reports will keep you busy for a while... 😄
Chilly Charly    (aka CC)
Message 3 of 13
(10,240 Views)
Ah .. yes ... the "someone else is in charge of that" thought pattern has struck again ... I will do that ... probably not anytime soon though (lots of work to do)  .... PDA Bug reports certainly do keep one busy at times.
Also .. on a follow up of the bug reported here
(Memory leak using slide indicators on front panel on PDA) ... or something like that ...
- There has been an update issued by NI to fix the memory leak ... the link to which can also be found on the original thread.
Well I'll provide the link to the original thread and to the patch to fix the problem here instead of making you hunt them down ... a little community service I suppose Smiley Wink
Thread
Patch
Greycat
Message Edited by Greycat on 07-12-2006 01:30 PM
Message 4 of 13
(10,181 Views)
Message 5 of 13
(10,153 Views)
Update to the "Memory Leak using slide indicator on front panel on PDA" bug.  There was another bug introduced by the patch, so NI has removed the patch, I'm assuming, until they fix it.  The thread can be read here.
So this is again an unresolved bug.
Greycat
Message 6 of 13
(10,116 Views)
The reference to a chart value does not accept array values confirmed bug by NI.
http://forums.ni.com/ni/board/message?board.id=170&message.id=195810
Joe.
"NOTHING IS EVER EASY"
Message 7 of 13
(10,059 Views)
Resizing IO-controls does not work correctly.
http://forums.ni.com/ni/board/message?board.id=170&message.id=196464
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 8 of 13
(10,002 Views)
There was no thread started on this, so the description will be placed here.
There is a known bug in LV8, fixed in 8.0.1 with stacked plot waveform charts, and changing the precision of the y scale.  See the example (make sure it's opened in 8.0.0).
Open the properties window and try to change the digits of precision of the Y-scales.  You're generally only able to change one.
Message 9 of 13
(9,931 Views)
A find by Rob Calhoun
There is a dataflow error in the vi.lib routine "Copy from Folder to Folder.vi" that is revealed by LabView 8.0.1
Message 10 of 13
(9,888 Views)
