BreakPoint
Monthly Bugs, January 2009
This is the continuation of the December 2008 bug thread
The rules are as always:
Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  1. One post/bug!
  2. One bug/post!
  3. No discussion of bugs. All discussions of a bug must take place in the original linked thread.
Message 1 of 24
(10,819 Views)
Front Panel objects relative position change when placing merge VI onto Block Diagram.
Reported by Jim Kring
details
Message 2 of 24
(10,788 Views)
details
This was reported to R&D (# 139212)
Message 3 of 24
(10,774 Views)
Documentation on the developer zone is misleading and incorrect as to how code in the Diagram Disable Structure is handled in memory.  The article referenced in this thread seems to indicate that LabVIEW Development System will not load the code in a Diagram Disable Structure into memory unless the block diagram is opened.  All code in the disabled cases is loaded into memory with the VI, regardless of whether the block diagram is open.  The stripping of the code appears to only happen in built EXEs.
Message 4 of 24
(10,738 Views)
Message 5 of 24
(10,708 Views)
TCP Listen does not destroy the listener it creates:
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=378178#M378178
___________________
Try to take over the world!
Message 6 of 24
(10,686 Views)
A minor bug : wires are always hidden behind pictures or decorations copied to the block diagram, even if these objects are "moved to back".
See here and below
Chilly Charly    (aka CC)
Message 7 of 24
(10,639 Views)
The title says it all.
See here for more details about what happen and how to reproduce it.
vipm.io | jki.net
Message 8 of 24
(10,593 Views)
Xcontrols dont play well with "defaults" actions. (Car # 44114)
(details)
Message 9 of 24
(10,555 Views)
Unchecking "Allow Undefined Strings" for System Combo Box Doesn't Work
CAR #41580
Message 10 of 24
(10,510 Views)
