BreakPoint
Monthly Bugs (January 2006)
This is the continuation of the December 2005 monthly bug thread.
Rules:
  • Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  • One post/bug!
  • One bug/post!
  • No discussion of bugs. All discussions of a bug must take place in the original linked thread.
  • Message 1 of 18
    (9,639 Views)
    Ok gurus....is this a bug (Labview 8.0 graph Bring To Center function)?
    Brian
    Message 2 of 18
    (9,579 Views)
    Another LabVIEW 8.0 bug:
    Value change events are no longer triggered if values are entered via tab key in a cluster control.
    Message 3 of 18
    (9,563 Views)
    Another small bug (Labview 8.0) with the numeric indicator and double data representation.
     If you set a double numeric indicator to have a minimum value and a nonzero increment value (see JPG) then, using the increment decrement button to the left of the indicator, increment past the minimum value and try to decrement back it wont go all the way to the minimum value.   It seem to be intermittant though.
    Brian
    Message Edited by BrianPack on 01-06-2006 03:37 PM
    Message 4 of 18
    (9,551 Views)
    Not exactly a bug, but clearly a mistake :
    No way to save a picture created on a PDA, even with the save fuction provided with LV PDA 8. See here.
    Chilly Charly    (aka CC)
    Message 5 of 18
    (9,532 Views)
    LV PDA 8 : There is a nasty bug in the display of graphic indicators (slides, meters, dials, tanks). See here
    Message 6 of 18
    (9,513 Views)
    Another LV 8 PDA bug : The unbundle by name operator does not work on subclusters. Described here
    Message Edité par chilly charly le 01-09-2006 08:10 AM
    Message 7 of 18
    (9,489 Views)
    When a vi makes multiple calls to a sub-vi with both Request Deallocation and a Current Vi's Path constant, the first call returns the expected value but subsequent calls return an empty path.
    discussion
    Message Edited by jasonhill on 01-10-2006 02:56 PM
    Message 8 of 18
    (9,459 Views)
    Brian wrote:
    "Another small bug (Labview 8.0) with the numeric indicator and double data representation.
     If you set a double numeric indicator to have a minimum value and a nonzero increment value (see JPG) then, using the increment decrement button to the left of the indicator, increment past the minimum value and try to decrement back it wont go all the way to the minimum value.   It seem to be intermittant though."
    Hi Brian,
    It's important that you report the presumed bug in the actual LabVIEW Forum. It's not possible for NI employees to track messages in the BreakPoint Forum.
    I will let the right people know about this one so you don't have to repost it, but for the future I'll ecourage you to simply use a link to your LabVIEW Forum post, thanks.
    Again, thank you for your valuable feedback!
    Message Edited by Philip C. on 01-13-2006 05:05 PM
    - Philip Courtois, Thinkbot Solutions
    Thinkbot Solutions
    Message 9 of 18
    (9,412 Views)
    Hello Brian,
    This issue has been reported to us before and will be fixed in the future versions of LabVIEW.
    We appreciate your feedback.
    Shakhina P.
    Message 10 of 18
    (9,369 Views)
