BreakPoint
Monthly Bugs (January 2006)
bug in LV8 for mac osx :
Write binary file is wrong for double arrays.
http://forums.ni.com/ni/board/message?board.id=170&message.id=161843
Boris
Message 12 of 18
(5,651 Views)
There is a property node available for the "Boolean text vertical arrangement" of booleans.
However, this property cannot really be set. Curiously, we can read this property, and it outputs "none".
From the online help:  Gets and sets the vertical arrangement for the text. You can set the vertical arrangement for labels, captions, and free labels.
(No mention of boolean text!).
Message Edited by altenbach on 01-23-2006 09:07 AM
Message 13 of 18
(5,607 Views)
LV 7.0 - A for loop outputs empty values even after its number of iteration was change from 0.
___________________
Try to take over the world!
Message 14 of 18
(5,582 Views)
Lv8.0 typedef does not connect to expression node
see http://forums.ni.com/ni/board/message?board.id=170&message.id=164014
greetings from the Netherlands
Message 15 of 18
(5,537 Views)
"Multiply Array Elements" with an U64 array input crashes LabVIEW (LabVIEW 8.0):
Message 16 of 18
(5,498 Views)
And don't forget to switch to the February 2006 thread (assuming there will be no more bugs today).
___________________
Message 17 of 18
(5,493 Views)
Wait!!!! We still have January 31, ~ noon! 😄
Message 18 of 18
(5,478 Views)
