BreakPoint
Monthly Bugs, December 2007
This is the continuation of the November bug thread.
  1. Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  2. One post/bug!
  3. One bug/post!
  4. No discussion of bugs. All discussions of a bug must take place in the original linked thread
___________________
Try to take over the world!
Message 1 of 13
(13,662 Views)
Double clicking the property node of an array element moves the array control to the position of the last modified elment:
___________________
Message 2 of 13
(13,660 Views)
Olsonse reports NI-Channel Name is not consistently used in all cases for Mixed Signal Graph
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=287824#M287824  CAR# 4G2E9E5D
Message 3 of 13
(13,640 Views)
Value property node links to the wrong typedef:
http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=289669#M289669
___________________
Message 4 of 13
(13,607 Views)
Vision Builder and LabVIEW: You need to open LabVIEW help to start generation of VIs:
http://forums.ni.com/ni/board/message?board.id=170&message.id=290194
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 5 of 13
(13,581 Views)
Fatal Internal Error: "image.cpp", line 13192 when trying to insert a cursor to graph
http://forums.ni.com/ni/board/message?board.id=170&message.id=290317
This was reported to R&D (#42FB3AVQ) for further investigation
Message 6 of 13
(13,554 Views)
Message 7 of 13
(13,504 Views)
LabVIEW strings do not properly display a \r\n or a \n\r EOL.
The first character is displayed as a space.  The problem goes back several versions of LabVIEW.
Message Edited by Matthew Kelton on 12-27-2007 01:18 PM
Message 9 of 13
(13,376 Views)
Message 10 of 13
(13,374 Views)
