BreakPoint
Monthly Bug Thread Jan 2007
Changing the constant format string label changes the output types on a Scan from String node.
See http://forums.ni.com/ni/board/message?board.id=170&message.id=224098
Joe Z.
Message 11 of 20
(7,923 Views)
LabVIEW 8.20 seems to blur blocky images under certain condition.
(download my example in the post above and e.g. move the upper slider to a lower value. LabVIEW 8.20 will blur the image under certain combinations of slider positions.)
Message Edited by altenbach on 01-15-2007 10:51 AM
Message 12 of 20
(7,914 Views)
Here you'll see a minor Application Builder display bug in LabVIEW 8.20
Ed
Ed Dickens - Certified LabVIEW Architect - DISTek Integration, Inc. - NI Certified Alliance Partner
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
Message 13 of 20
(7,879 Views)
The function "to uppercase" works fine with strings, integers, enums, etc. and e.g. clusters containing a mix of strings and integers.
If the cluster contains a string and an enum, we get a compile error.
Message 14 of 20
(7,827 Views)
On LAVA
http://forums.lavag.org/renaming-Channel-names-on-WF-Chart-crashes-LV-t5942.html
CAR# 45M2HEA4
Work-around:
Select
Pop-up >>> Ignore attributes
Ben
Message 15 of 20
(7,821 Views)
Issue with variant to timstamp in LV 8.2
http://forums.ni.com/ni/board/message?board.id=170&message.id=225869&jump=true
Reported as a known issue. Waiting on the AE to provide the CAR#
Ben
Message 16 of 20
(7,819 Views)
Bug Description is on LAVA
http://forums.lavag.org/Some-data-randomly-loose-its-name-when-coerced-to-variant-t5994.html
PJM
vipm.io | jki.net
Message 17 of 20
(7,799 Views)
The code in the link exposes an error in mathscript that can give a wrong sized array output under certain conditions:
N=8191 -> size=8191
N=8192 -> size=8191 (???)
N=8193 -> size=8193
Message 18 of 20
(7,755 Views)
Due to poorly undestood factors in the time/space continuum February has arrived, making this thread obsolete.
Let's all continue in the new and improved February version of same.
Happy bug hunting! We know they're out there somewhere.
Message 20 of 20
(7,685 Views)
