BreakPoint
Interesting Stats
I decided that I needed a little practice with regular expressions so I challenged myself to compose a single regex that would parse the useful data from the source of the forum pages.  It wasn't quite 'War and Peace', but there were a couple of lengthy expressions.  The side effect was that I generated a large dataset, and can now look at some statistics I couldn't before.
Kudos for 2009.
The distribution of Kudos for posts is very close to a Poisson distribution with an expectation value of 0.154 Kudos per post (I had to exclude the exploits of one individual whose weekly posts skew the distribution of high-Kudoed posts).  Some percentages:
Kudos (percentage)
0 (84.5)
1 (12.7)
2 (2.1)
3 (0.5)
4 (0.1)
>4 (0.1)
Once you hit 3 Kudos, you are in rarified air indeed.  Even 2 gets you an 'A+'
Solutions:
In 2009 there were roughly 13500 threads started, and 3911 solved (in 2009), a roughly 30% success rate.  Can you guess who the top 5 solvers were over the past 6 months (Aug 1 - Feb 1)?  The top 3 are no surprise, number 4 surprised me somewhat, and there is a three-way tie for fifth with two easy guesses and one interloper.
Interesting reads.
Eventually, I want to find ways to quantify interesting threads, a couple that I found during this exercise (hopefully an interesting stroll down memory lane).
Top Kudoed solutions:
http://forums.ni.com/ni/board/message?board.id=170&thread.id=411279
http://forums.ni.com/ni/board/message?board.id=170&thread.id=392472  (timeless classic)
Not-so-Kudoed
http://forums.ni.com/ni/board/message?board.id=170&thread.id=439600 (solved in first reply, followed by six pages of more replies)
Patience is a virtue:
http://forums.ni.com/ni/board/message?board.id=170&thread.id=107332 (only took 4 years to solve)
Finally Kudos/Post on LabVIEW board in 2009:
Top 5 for 2009 posts: (min 100 posts)
1. Darren 2.25
2. DFGray 1.03
3. Ben 0.76  (over 1800 posts!)
4. JarrodS  0.69 (sensing a trend)
5. Darin.K  0.66 (even a blind squirrel...)
followed by Andrey Dmitriev, altenbach (again sustained over 1700+ posts),mikeporter, Mathew Kelton,tst, and Ray.R
Message 1 of 19
(11,851 Views)
Darin.K wrote:
...(I had to exclude the exploits of one individual whose weekly posts skew the distribution of high-Kudoed posts)...
Hey, I represent that remark!
Message 2 of 19
(11,847 Views)
Could you share some of the magic (regexes)?
I alway struggle my through them and alway have a feeling I can do it in a better way.
Ton
My LabVIEW Ideas
Message 3 of 19
(11,846 Views)
Maybe I was talking about dixy normous
Actually, 2+ Kudos/post is just plain sick.  well done.
Ton
I'll clean up some of my code, and post a VI with some sample text and the regex and see if we can't whittle away some more of it.  So much trial and error, mostly error.  The hard part is that the more complex you make it, the more suceptible you become to a single glitch throwing off the entire match.
Message 4 of 19
(11,834 Views)
Darin.K wrote:
...Maybe I was talking about dixy normous
Any relation to Moxy Fruvous?
Message 5 of 19
(11,831 Views)
Actually the point in the solution was explained in the replies and after a lot of going back and froth i made my point.......lol!!!
Message 6 of 19
(11,788 Views)
Here is the VI I used to fine tune the regexes.  It will bold the text that matches in the control.  This text is extracted from a page listing threads, I basically clean the string (remove newlines) and find the individual threads by extracting the text between two tags (<tr> and </tr>).  The text here is for a solved thread with Kudos.
Message 7 of 19
(11,745 Views)
Thank you very much!
I set as  a goal of "0.5 over-all time" years ago to keep me from posting too much and keep the quality up. Once I reached it, I started using any Kudos over 0.5 as a license to post another reply. Since I only have access to the totals, I could not know what you have reported about the recent past so "a tip-of-the-hat" to you sir and again, thank you!
Is this something that can be run across all contributors and be posted as a spreadsheet?
Ben
Message 8 of 19
(11,735 Views)
Something like this, all contributors who received at least one Kudo in 2009 (at least for a post in 2009).
Message 9 of 19
(11,727 Views)
Nobody wants to play the guessing game for the last six month solvers so I'll simplify a little.
1.  smercurio_fc (117)
2. Dennis Knutson (112)
3. Ravens Fan (102)
4. ??? (59)
5t. altenbach, Ben, Darin.K (57)
Who is the mysterious number 4?  It made sense once I knew, but it would have taken me a very long time to guess it.  Only mystery in the top 3 was the final order, and I was a little surprised to be interloping at 5, but it looks like ok company there.
Message 10 of 19
(11,703 Views)
