BreakPoint
Create Constant/Indicator/Control Block Diagram Changes
So I don't even know what I want anymore when it comes to this but I just felt like I needed to get something out as a bit of history for my own sanity.
So back in LabVIEW 2019 a new feature was added which added the Create Constant, Create Control, and Create Indicator at the top of a menu after right clicking a terminal.  I was resistant to it mostly because it was ALWAYS there, even on operations when a create isn't the most common thing you want to do.  Terminals out of a loop often need Indexing, Conditional, Concatenating, or Last settings.  A Boolean, Enum, and Error going to a case structure I often want to use Replace With Case Selector.  Creating things is not what I want here.  The feature when it was new was talked about in several places like this thread.  One argument for it was consistency.  You always know those 3 top things will be there, whether you need them or not.
Time marches on and developers start getting used to this feature.  I was reluctant, and still say the feature should be more intelligent, but still I used it and didn't use the INI key that got rid of them.  But then in LabVIEW 2023, NI decided to remove these right click features because there is now a new feature.  Double click to create controls/indicators/constants.  I mostly like this feature.  It will take time to get used to it.  I will miss being able to break a VI by just dropping down a broken wire by double clicking a random spot, then double clicking another, then putting down a comment saying why I broke it.  It isn't elegant but it is quick. (does anyone have a better work flow for this BTW?  Maybe a QuickDrop force break?)
Well NI decided this feature was good enough to remove the right click menu.  So much for being consistent I guess.  And while searching for this I found a thing on the idea exchange, to add a double click for creating these objects, and it was declined, because "NI will not implement this idea, in 2019 and later the Create menu options for terminals are always available a the top".
At this point I don't even know what I want.  There are INI keys to have the double click have the old behavior, and there are right click tools that likely could restore the original Create menus, but also I kinda got used to them, but also I don't like them in some situations.  I'm just frustrated at IDE behavior changes. I get that if NI would make these new features Opt-In that there probably wouldn't be much adoption. But I do remember back in the day NI introducing new features as an INI key for a version, then adding it officially like Quick Bold.  And that wasn't even a huge change.
(445 Views)
I love the double-click to create feature. But I also wish the 'Create' menu options were still at the top, because I still want to be able to create a constant/control/indicator (usually a constant) from anything that defines a data type, including a wired terminal or a wire. So even though I double-click to create dozens/hundreds of times a day now, I still use the INI token to re-add the menu items so I can use them on wired terminals and wires: PopupMenus.ElevateCreation=True.
With these changes, you can still tack down a broken wire... use Alt-Double Click for that now.
(402 Views)
"I love the double-click to create feature." - Me too. Using it all the time.
(153 Views)
I'd probably like it more if it were in every version of LabVIEW I use. I'd like the Create Menu if it were in every version of LabVIEW I use.  As it is I think the IDE whiplash is part of my complaint.  If you've ever tried to develop in LabVIEW 1 on the demo floor of NI Connect you'll notice how features are missing.  I get that progress needs to happen, but features being added in one version, then removed later is what is weird.  Thanks Darren to at least add those menus back.
(136 Views)
