BreakPoint
A call for obfuscated LabVIEW code
No, I think it's all klingon.
___________________________________________________________________
Still confused after 8 years.
Message 61 of 85
(19,825 Views)
Allthough this is a bit old thread, it's the breakpoint and a big thread, so anyone in need for obfuscating code will have a look through. That's why I link that thread:
Why does LabVIEW allow me to have 2 controls with same name
So, while you use Caption for your FP, you can have a consistent equal label name for all your controls 😉
Felix
Message 62 of 85
(19,668 Views)
Felix!
That idea is border-line cruel!
Ben
Smiley Very Happy
Message 63 of 85
(19,639 Views)
 I really give up. Can someone explain this (HelloWorldJP.vi) to me please?
Message 64 of 85
(19,021 Views)
The key is in understanding how the type cast works and how LabVIEW represents a boolean.
  • A type cast takes a bit pattern in memory (let's say you have an 8 bit integer whose value is 00110101) and rereads it as the new data type (in this case a string with the value 53, or "5").
  • A boolean is represented as a whole byte. If any of the bits is true, then the boolean is true. In this case, taking the string "Hello World!" and typecasting it to a boolean array results in an array of 12 bytes, which can then be saved as a constant.
You can see this if you look at the actual bits:
___________________
Try to take over the world!
Message 65 of 85
(19,017 Views)
LAVA has a thread on Obfuse code that can be found here.
Ben
Message 66 of 85
(17,940 Views)
What confuses me about JP's code is this:
If you look at the constant, they're all 'T'.
When you press run, it says Hello World.
If you change 1 of the booleans to F, then back to T,
it no longer says Hello World.
Why is this?
Cory K
Message 67 of 85
(17,821 Views)
Did you read tst's explanation above?
Basically, the boolean array was generated by typecasting the desired string to a boolean array. Once you toggle a boolean, the value will get "normalized" and thus the extra information is lost.
Message Edited by altenbach on 05-22-2009 07:57 PM
Message 68 of 85
(17,814 Views)
Ok I am really REALLY late to this thread.
LabVIEW 2012
Message 69 of 85
(15,896 Views)
Running it locked up my computer completely. 😞
Message 70 of 85
(15,871 Views)
